I need help finding a exhaust shop nearby to replace from muffler back on our 2000 holiday rambler palm springs. We blew a rear tire and it tore our exhaust off. We are having a hard time finding anyone that does 3 inch pipe.
Thank you all again for your help. A local rv'er sent us to Larry's Radiator and exhaust. Custom bent tailpipe welded on and generator exhaust repair only 160.00 out the door. great People
I know it is not in Palm Springs area, but Redlands RV in Redlands, CA, either can do the work or can refer you to a shop that can do the work. Suggest giving Redlands a call and discuss your needs, and I believe they will be able to help you. Good Luck
Kevin.....If you're handy, it might be easier to order the parts and clamp them on, unless the muffler end was damaged. Several companies make the 3" pipe in straights and turns, especially the shops selling RV mufflers.
Don & Mary 2019 Newmar Dutch Star 4018 - All Electric 2019 Ford Raptor Crew Cab
