High altitude driving issues
havinablast
Has anyone else had issues with temperature going up on their motorhome when you are driving at high altitudes? It also feels kind of sluggish. We drive a 2000 Fleetwood discovery. Temp comes right down when altitude drops. And it drives fine. Any suggestions.
22 REPLIES 22
Searching_Ut
You didn't mention if the cummins had a turbo or not, but I'll assume it's a turbo. One possibility might be the fan not pulling enough air across the radiator. As air density decreases, the fan will pull less volume for any given RPM. It's been to long since I took my aircraft powerplant classes back in the 80's for me to remember the formulas, but it seems a fixed prop lost about the same amount of power as an engine, which you could get pretty close to calculating by figuring 3 percent per thousand feet.
All that said, I've never noticed what you're experiencing.
2015 Ram 3500 Laramie CTD, 4X4, AISIN, B&W Companion Puck Mount
2016 Heartland Bighorn 3270RS, 1kw solar with Trimetric and dual SC2030, 600 watt and 2k inverters.
wolfe10
With your rear radiator/CAC, have you checked the from of the CAC for blockage?
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
havinablast
Freightliner chassis with a 300hp cummins. It isn't steep hills its anytime above 6500' and of course more noticeable on a climb.
havinablast
We are from Alabama, and are currently heading through Wyoming. So the altitudes here are much greater. The temperature is moving higher above 6500'. We will check the air filter as soon as we stop again, and the radiator cap.
wolfe10
Please let us know what engine/chassis you have.
And is it elevation related or only on steep uphill sections?
Brett Wolfe
Ex: 1997 Safari 35'
BigSkyBob
I'm not sure what you mean by "high altitudes. I regularly operate my rig on mountain passes exceeding 7000' and have never noticed any indication of high coolant temps or loss of power. Perhaps your air filter & radiator requires some attention.
2008 Monaco Camelot 40PDQ, 4 slides, 2016 Dodge Ram 1500 Hemi Quadcab 4x4. Blue Ox, Garmin 760 LRM GPS, Doran Pressure pro on all 10, M&G Brake, 50 amp SurgeGuard, FMCA, Coachnet.
skipnchar
With a normally aspirated engine (no turbo or super charger) you will be loosing something like 10% of your horse power for each thousand feet you go above sea level. If you have a turbo diesel or turbo charged gasser, this power loss is almost non existent. Also keep in mind that water (also coolant) will boil at a MUCH lower temperature at high altitude so you MAY have lost some water from your radiator. Check to be certain you have a GOOD radiator cap on your engine to keep the coolant under correct operating pressure.
2011 F-150 HD Ecoboost 3.5 V6. 2550 payload, 17,100 GCVWR -
2004 F-150 HD (Traded after 80,000 towing miles)
2007 Rockwood 8314SS 34' travel trailer
US Govt survey shows three out of four people make up 75% of the total population
The_Texan
How long since you cleaned the "backside" of your radiator stack? Ours started doing that and as soon as I cleaned the crud of the backside of the radiator and allowed it to breathe again. the temps immediately went down at altitude.
Bob & Betsy - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
2005 HR Endeavor 40PRQ, '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/2017 Rzr 4-900 riding in 16+' enclosed trailer in back.
Where the wheels are stopped today
