How can youtell if you have a heat pump?
supercub
I have a 07 Fleetwood Southwind 32V, has two roof mounted AC units, anyway to tell if one or both are heat pumps? Thanks
Brian
3 REPLIES 3
dougrainer
By the Model number of the AC unit, or you remove the top shrouds and IF you have a Heat Pump, you will see a solenoid/valve assbly mounted in the copper lines. It will have 4 copper lines going to it. Model number is the easiest way. Doug
Tom_N
If the compressor runs in your A/C unit and heat comes out your vents, you have a heat pump.
If just the fan in your A/C unit runs, you have an electric heat strip.
-Tom
Sarver, PA/Crystal River, FL/Shelocta, PA ยท W3TLN ยท FMCA 335149 ยท Mystic Knights of the Sea
2005 Suncruiser 38R ยท W24 chassis, no chassis mods needed ยท 2013 Honda Accord EX-L ยท 2008 Honda Odyssey EX-L
wilpower
I presume you have Coleman AC's? Any indication on your thermostat? On the Dometic thermostat, there is a setting for "heat pump"
