May-18-2020 12:10 PM
May-18-2020 05:18 PM
May-18-2020 04:20 PM
dougrainer wrote:
If you have a slide cover, it must be removed or flipped on top the roof to replace the seal. Our shop charges from 2.0 to 3.0 hours to do the Metal teeth seal. That includes removing or flipping the slide cover. If no slide cover, 2.0 hours. You really need strong fingers to get the teeth onto the slide track guide. It is just a matter of working the new slide seal in place a few inches at a time. You start at either the front or rear bottom sidewall and work it up and across and down. You must also make a slit at the 2 top corners to get the wipe seal to fit evenly. Doug
May-18-2020 04:02 PM
May-18-2020 03:48 PM
Captain_Happy wrote:
First of all take picture s of how the deal are installed on your class a, then order the right seals, like you ones your about to pull off. Check how the seals over lap in the top corners before you start.
I helped my brother put his on his class B.
May-18-2020 03:35 PM
