How do I get speakers to work???
bonniesoo
This is probably a stupid question but I can't figure it out....we have a 2009 Monaco Camelot & the only time the speakers in the motorhome work is when watching a DVD...we end up having to turn the Tv up almost all the way to hear it. Isn't there some way to hook the tv up to the speakers in the motorhome? Thanks for your responses... Sincerely, Technically Challenged!
Kim & Donna Hale
2009 Monaco Camelot
2016 Ford Explorer
Suki & Mayla- 2 spoiled pekingese
Our precious Mika ( at the Rainbow Bridge)
Hook'em Horns
5 REPLIES 5
-Gramps-
Was it the aux input on your dvd player?
___________________________________________
Fulltimer in 08 Holiday Rambler Vacationer 38PLT Workhorse UFO GAS Pusher Chassis
06 Saturn Vue toad, SMI Breaking sys,Blue Ox tow bar.
My Random Views Blog
bonniesoo
Thank you thank you...my hubby was able to make it work from your info....we are happy now & can hear tv!!
Kim & Donna Hale
2009 Monaco Camelot
2016 Ford Explorer
Hook'em Horns
Executive45
I used these guys. They came to the coach and installed the surround system for me. I wasn't going to fiddle with all that wiring. They also had to switch out all the ends as the one's Monaco used were outdated...good luck....Dennis
We can do more than we think we can, but most do less than we think we do
Dennis and Debi Fourteen Years Full Timing
Monaco Executive M-45PBQ Quad Slide
525HP Cummins ISM 6 Spd Allison
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
sch911
On our 2009 HR (same as Monaco) we have to select the correct source input for the Sourround Sound receiver which is what powers the speakers. Pretty sure there is a DVD, FM radio, TV, etc.. Ours is a Samsung system.
OEM Auto Engineer- Embedded Software Team
rgatijnet1
Most TV's have an audio output that must be connected to the same amplifier as used by your DVD. Assuming that you have it already hooked up properly, go to the menu portion of your TV set-up and make sure that you have specified an external speaker/amplifier.
