Mar-24-2018 05:46 AM
Mar-24-2018 01:59 PM
Mar-24-2018 11:42 AM
Mr.Mark wrote:I had had that thought, in fact that is how I had solved it so far. Just wanted to make sure there wasn't something else I was supposed to be doing.
Mr. Bob, I would think that if you want it truly off, you need to flip the breakers for it. I assume that when you say 'switches' that you are just talking about the 'on/off' switches.
I have a tankless water heater for our shower, I have to turn the breaker off for it not to heat. We also have an electric hot water tank that us sufficient for us if I need to watch electric power. The 'tankless' will pull some amps.
Safe travels,
MM.
Mar-24-2018 11:38 AM
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
Mar-24-2018 11:37 AM
jorbill2or wrote:No it is not an Oasis or Aqua-hot system. It is a true tankless water heater. I'll be back to it sometime tomorrow and I will check on the brand name and pass it on to you.
By that year Dutch star should have a standard oasis diesel hydronic heat shouldn’t it ? I guess you could call it tankless but not boiler-less. Don’t have a oasis but lots of info ( google) if you have that. My Aqua hot heats by the engine , diesel or electric and because it’s well insulated keeps “warm” water for hours. It’s not tankless as mine has a 15 gallon boiler the coiled hot water line runs through (around in my case)
Mar-24-2018 09:32 AM
bobkatmsu wrote:
I have a new to me, 2010 Newmar Dutch Star 4369. It comes with an on-demand tankless water heater. It has been parked the past week, hooked up to a 30 amp service. I have had both the electrical and propane switches to the water heater turned off. Just for the heck of it I turned on the hot water at a faucet and got...hot water. How does that work?
Mar-24-2018 09:18 AM
Mar-24-2018 07:06 AM
Mar-24-2018 06:21 AM
Mar-24-2018 06:20 AM
