How does your brand label the sides of the coach?
holstein13
I was talking to a service technician today who was complaining about the way the different manufacturers labeled the sides of the coach. For example, Newmar uses DS = Door Side and ODS = Off Door Side. But others use DS = Driver Side versus PS = Passenger side. Still others use Curbside, and RS = Road Side but sometimes RS = Right Side and LS = Left Side.
To make matters worse, he could not get his service managers to agree on nomenclature so he would often get descriptions of service issues that referenced DS or RS and it meant nothing to him because there was no standard. At least with boats, they use port and starboard.
So how does your manufacturer label this?
BTW, this isn't only an issue with the sides. On my Newmar Coach, they use 5 different terms to describe the two types of shades.
In the cockpit, a "shade" is the blackout shade and the see through ones are just a "visor."
On the passenger side, the "shade" is the see through shade.
In the living room and coach area, there are "Day Shades" and "Night Shades"
And in the console above the driver's seat, the blackout shades are referred to as "Privacy Shades."
I can see how different manufacturers might use different terms, but having one manufacturer use several terms for the same thing, seems senseless to me.
Of course I've gotten used to it and know what each button does, but I can see how confusing this must be for service people who have to work on lots of different coaches.
2015 Newmar King Aire 4599
2012 Ford F150 Supercrew Cab
14 REPLIES 14
Passin_Thru
o is on, i is interrupted
holstein13
Executive wrote:
In order to get it right, you have to know what the writer meant. What do you think this guy meant...????....Dennis
I think it means if you arrive between 7 and 8 you can park for two hours only. If you arrive any other time, you can park as long as you'd like. ๐Ÿ˜‰
Executive45
We can do more than we think we can, but most do less than we think we do
Dennis and Debi Fourteen Years Full Timing
Monaco Executive M-45PBQ Quad Slide
525HP Cummins ISM 6 Spd Allison
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
Mr_Mark1
On the dash read-out... if I have not closed one of the bay doors, it will say 'baggage door open'.
MM.
Mr.Mark
2021.5 Pleasure Way Plateau FL Class-B on the Sprinter Chassis
2018 Mini Cooper Hardtop Coupe, 2 dr., 6-speed manual
(SOLD) 2015 Prevost Liberty Coach, 45 ft, 500 hp Volvo
(SOLD) 2008 Monaco Dynasty, 42 ft, 425 hp Cummins
dougrainer
The MAIN point is---The SERVICE WRITER is the one that has to type up the repair order and HE is the one that talks to the customer and goes over the complaints and "Hopefully" actually goes out to the RV and goes over it with the customer. Regardless of what the customer says, that Service Writer is the one that is responsible for relaying the correct info to the Technician. Also, another pet peeve, I wish the customer would REALLY read the RO he is signing. That way, IF there is a mistake, the customer can catch and state that the RO does not state what and where his complaint is. It seems a lot of older RVers are dead or gone. I can remember years ago, it did not matter what brand Motorhome you had, a LOT of people said you had a Winnebago. That was the layman's term for any motorhome they saw. I rarely hear that term anymore when people are talking about motorhomes. Doug
Cloud_Dancer
DrewE wrote:
Cloud Dancer wrote:
Yeah. Like on a simple on/off switch,.....what does o & i stand for?
It's binary, zero and one. Zero is off, and one is on. These markings have been pretty common and standardized for a good many years.
Thanks, now I know where it comes from. I wish they had used intuit, and simply put a + for ON.
Willie & Betty Sue
Miko & Sparky
2003 41 ft Dutch Star Diesel Pusher/Spartan
Floorplan 4010
Blazer toad & Ranger bassboat
Executive45
Monaco labeled "The Executive" on both sides of my coach. They only put a logo on the front and rear caps..:W..Dennis
My winnie had doors on BOTH sides so that argument won't fly..just sayin
sailor_lou
Travel Supreme uses the same nomenclature as Newmar, DS = Door Side and ODS = Off Door Side. This may be because from what I have read, TS was started by former Newmar employees.
Lou
05 Travel Supreme Envoy
dougrainer
holstein13 wrote:
dougrainer wrote:
Sorry, but if the so called tech was complaining about that, I suspect he does not know his job that well. ALL the terms you listed make sense to anybody that has been in the RV or Automotive business. RS and LS are ALWAYS stated when SITTING in the drivers seat. That said, a lot of RV owners have no clue when they bring them in for service and it is up to the Service advisor to clarify which side the customer is indicating. Doug
MY pet peeve and is on this forum a lot. " I try RAISING the Jacks and the RV will not level". Raising the jacks means retracting them. Extending or LOWERING the jacks will get your RV level.
Not really. All the tech sees is "DS slide malfunctioning." What does that mean? Door side or Driver's side? Who knows?
Simple, DRIVERS side. NOBODY ever uses DS as Door Side IN the Service business. This type complaint would be up to the Service writer to get straight. Granted, for parts, OEM's will use DS(door side) and ODS(off door side). Doug
holstein13
dougrainer
Mr_Mark1
Our exterior lights are referred to as follows:
Starboard Cargo
Port Cargo
Aft Cargo
Aft Docking
Shades are numbered individually or can be done all at the same time. Also offers a blackout feature.
The dash shades are referred to as 'driver' or 'passenger'.
MM.
Mr.Mark
DrewE
Cloud_Dancer
Willie & Betty Sue
Miko & Sparky
Floorplan 4010
