โJun-12-2013 07:04 PM
โJul-11-2013 05:05 PM
Harvard wrote:
I do not know anything about nitrogen in tires BUT I hear (from the TV) that wood/lumber kept under water and deprived of oxygen will last for many years. Maybe the nitrogen in a tire will displace the oxygen and reduces whatever oxygen does to encourage the rotting process.
โJul-11-2013 01:06 PM
โJul-11-2013 12:14 PM
โJul-11-2013 11:33 AM
โJul-11-2013 11:03 AM
Harvey51 wrote:I thought the advantage with nitogren was for psi stability. Hot or cold it's the same. Am I right?
All gases follow the universal gas law PV= RT so nitrogen filled tires respond exactly the same way to temperature changes. There is a temperature/pressure affect when there is liquid water condensed in the tire and then it heats up and goes gaseous - this doesn't happen with nitrogen because water is removed completely in the process of seperating it from air by liquification.
Some say oxygen can find its way through the rubber slightly more easily so pressure may drop less over winter with nitrogen. If true, this also implies that oxygen will pass from the air outside into the tire with no oxygen so your nitrogen filled wheels may actually slightly increase in pressure over time.
More info here: http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=191
โJul-11-2013 09:58 AM
โJun-29-2013 11:49 AM
โJun-28-2013 06:24 PM
โJun-27-2013 08:46 AM
โJun-27-2013 06:26 AM
bigcitypopo wrote:
I have heard that Aerospace 303 is good stuff, but I would also get some tire covers... and probably a coach cover as well.
โJun-27-2013 06:22 AM
โJun-27-2013 06:13 AM
โJun-27-2013 06:11 AM
โJun-27-2013 03:45 AM
