How long should tires last before they dry rot?
Nevadastars
We just picked up an immaculate and well kept 2010, 25ft Chateau. I was so impressed with the condition of it, it was a no brainer to buy it. But, after I got it home, I noticed the tires are severely dry rotted. The rig has 10k miles on it and has always been covered expect when on the road. The tires are Michelin LTX which I assumed where one of the better brands out there. Is this normal for only 3 years old?
2016 Forest River Wildcat Maxx 262RGX 8,268 UVW 11,754 GVWR
2007 Ram 2500 QC SB 4x4 Smarty tuned 5.9 Cummins
B&W Turnover Ball & Andersen Ultimate
53 REPLIES 53
Nevadastars
Harvard wrote:
I do not know anything about nitrogen in tires BUT I hear (from the TV) that wood/lumber kept under water and deprived of oxygen will last for many years. Maybe the nitrogen in a tire will displace the oxygen and reduces whatever oxygen does to encourage the rotting process.
Just to be clear, I got the nitrogen strictly for tire pressure stability. I have no idea whether it helps or hurts dry rotting, although I cannot see how it could affect the outside of the tires.
Harvard
Mich_F
This goes back a lot of years to 1995, when I bought my first class C. It came on Michelin tires. Those tires were on that MH for slightly less than 50,000 miles, and slightly less than 10 years, when I replaced them, after getting two blow outs in a short period of time. The first blow out was on a tire that had a flat many years before and it was plugged, instead of being patched.
Those tires still had plenty of tread left. The main thing ( I think) that let them live that long was the fact the MH was used as a daily driver for those ten years. Back and forth to work or wherever for their whole life. This was also 10 years (or almost) in Florida.
2014 Itasca Spirit 31K Class C
2016 Mazda CX5 on Acme tow dolly- 4 trips ~ 5,800 mi
Now 2017 RWD F150 with a drive shaft disconnect
Grandpa_Joe
We keep ours covered and use Aerospace 303 when we go out for a trip, going on 4years old, 10K miles look great.
adayjk
Harvey51 wrote:
I thought the advantage with nitogren was for psi stability. Hot or cold it's the same. Am I right?
All gases follow the universal gas law PV= RT so nitrogen filled tires respond exactly the same way to temperature changes. There is a temperature/pressure affect when there is liquid water condensed in the tire and then it heats up and goes gaseous - this doesn't happen with nitrogen because water is removed completely in the process of seperating it from air by liquification.
Some say oxygen can find its way through the rubber slightly more easily so pressure may drop less over winter with nitrogen. If true, this also implies that oxygen will pass from the air outside into the tire with no oxygen so your nitrogen filled wheels may actually slightly increase in pressure over time.
More info here: http://www.tirerack.com/tires/tiretech/techpage.jsp?techid=191
It called the "ideal gas law" because it only really estimates what might happen. While I can imagine a molecule or two of O2 from the air gettng into a tire, the oxygen (and air) will move towards a state of greater entropy. Maybe you are thinking of the gas constant? Under the ideal gas law, gasses of a different mole weight will behave differently. The law also does not consider things like leakage rates, moisture content, and the reactivity of the elements and compounds involved. Crunch the math on gasses at the proposed pressures and temps and you find it makes no difference anyway.
Pv=nrt often get brought into the N2 conversation, but it all it really shows is that all gasses are good at filling tires. Its the phase change of Condensable materials that can alter the pressures more radically. In other terms, things in there that turn to liquid or solids under reasonable temperatures are a bigger problem. H2O is one material that comes to mind.
JeffH
Michelin tires seem prone to this problem. I have had two sets of tires replaced on my unit so far and it is only 8 years old. The problem is two-fold: Lack of regular use and exposure to sun. I am happy that Michelin is a respectable company. They have replaced both sets under warranty, prorated for treadwear. They covered 85% of the cost the first time and 65% the second time. I know the sun is a factor because the second time they only replaced the front tires and the outer duals. The inners were in good condition. They put the inners on the front axle and the 4 new ones went on the duals. As long as they continue to cover them I will continue to stick with Michelin. I bought replacement tires for my Dodge Dakota from Michelin because of the good customer support. I have been happy with the set on the truck. Our new Toyota Sienna has Michelins too.
Jeff, Heather, Megan, and Josh
2005 Jayco Greyhawk 30GS
Harvey51
2004 E350 Adventurer (Canadian) 20 footer - Alberta, Canada
No TV + 100W solar = no generator needed
the_trippers
Another advantage of nitrogen over air is the absence of oxygen in the mix, which can oxidize & rot the tire from the inside.
2018 Tiffin Allegro 32SA
Bordercollie
I replaced six Michelin tires a year ago after a number of years of non-use. Some were 4.5 years old some were 8 years old, all had enough sidewall cracks to be suspect. The Socal sun, summer temps, sitting mostly undriven and not using tire covers seems to shorten tire life considerably. Wish we could get some cold hard facts on RV tire life not confused by hearsay or brand loyalty.
Nevadastars
bigcitypopo wrote:
I have heard that Aerospace 303 is good stuff, but I would also get some tire covers... and probably a coach cover as well.
I have an RV carport with full sides and closed rear coming, but they are 2-6 weeks out before then can set it up. Can't wait to get our beautiful rig under cover!
bigcitypopo
2014 RAM 2500 BigHorn CrewCab 4x2 ShortBox, 6.7L CTD
2014 Keystone Springdale 294bhssrwe - Hensley Arrow!
The best wife, 2 kids and a bunch of fun
Nevadastars
edit: double post
Nevadastars
That could be true, but they told me when I picked up my rig from the tire shop with new BFGs, that they are less likely to lose pressure over time like air would. For another $10 per tire, I took the chance.
ron_dittmer
