How long should tires last before they dry rot?
Nevadastars
We just picked up an immaculate and well kept 2010, 25ft Chateau. I was so impressed with the condition of it, it was a no brainer to buy it. But, after I got it home, I noticed the tires are severely dry rotted. The rig has 10k miles on it and has always been covered expect when on the road. The tires are Michelin LTX which I assumed where one of the better brands out there. Is this normal for only 3 years old?
2016 Forest River Wildcat Maxx 262RGX 8,268 UVW 11,754 GVWR
2007 Ram 2500 QC SB 4x4 Smarty tuned 5.9 Cummins
B&W Turnover Ball & Andersen Ultimate
53 REPLIES 53
midnightsadie
just for fun,I,d take the rv to a mich dealer see if theres a warrenty of sort, can,t hurt. mine are 7yrs old look great .but I store indoors.
ron_dittmer
Our 2007 rig has the same brand tires as the OP. They are original with 17,000 miles and still look and smell like new. But our rig stays indoors in climate controlled storage which apparently makes all the difference.
I don't worry about the age of our tires, not only because of condition, but also because our rig is 4000-4500 pounds lighter than most when loaded for a trip. The load my tires see is significantly less than they are rated for.
TyroneandGladys
Covered or not they are still subjected to the heat. With us being in Phoenix we halve always changed out tires out at 3 year on all of our vehicles. Unfortunately I started to listen to people that said that was excessive. Tires on Glady's vehicle were 3 years old in January and in the last three weeks had two tire fail because of the belts separating, Tires still had 50% tread. She now has 4 brand new tires and I WILL change tires at three years I do not care what anyone says the safety of my family is not worth saving a few bucks. But that is my choice and your choice is your choice.
FYI it is not uncommon on motor homes that if a rear tire fails for it to do over a thousand dollars in damage to the body of the RV, LP lines ,water lines, brake lines and electrical wiring.
Tyrone & Gladys
27' 1986 Coachmen
Nevadastars
Not exactly sure if the tires were covered, but the unit itself looks new on the outside, very shiney with no fading whatsoever. We bought it off a car lot while it was on consignment. We met the elderly owner and he was anal about keeping records and keeping the rig in top shape. He just said he had a carport type cover for it, but not sure if the sides were covered, although like I said, it shines like it never spent any time in the bright Nevada sun.
Either way, I guess it needs new boots, but they are not going to be replaced soon as we still need to register it at $1000 dollars and my wifes car needs tires first. This was a totally unexpected turn of events. We were so taken in by the overall condition of the rig, I never even looked at the tires closely.
path1
I think you are reading dates codes right. But even in a state that has a lot of UV rot, that is excessive. And you said they were covered? Well you can't fix them...Time for new.
Last bunch I bought was Goodyear "wrangler" so far no problems other than one valve extender keeps wobbling around, going to use RTV on the valve stem threads and see what happens.
2003 Majestic 23P... Northwest travel machine
2013 Arctic Fox 25W... Wife "doll house" for longer snowbird trips
2001 "The Mighty Dodge"... tow vehicle for "doll house"
Nevadastars
If I am reading the date codes correctly, they were built the 19th week of 2009. The codes are DOT B 36 J FBXX 19 09. I do live in a very dry state if that makes a difference. Thanks for the quick replies.
path1
No. Go by the date codes on tires, not model year of RV. Maybe tires got swapped out?
P.S. Came real close to buying one of those last year. Went home to think about and was sold when I called next day.
Ro646a
I put a set of new Michelins on our former motor home and they were all cracking at 2 years old. I put new Bridgstones on the our current rig on recommendation from the tire dealer. So far I'm happy with them at 19 months and 8000 miles.
Roland
1999 American Dream 40 DVS
2011 Jeep Liberty
Roadmaster Sterling Towbar
Brake Buddy
SAR_Tracker
I'd be willing to be the tires are older than 2010.
How to determine the age of your tires
Rusty & Cheryl
2011 F250 2WD 6.2L Gasser
2008 Weekend Warrior FB2100
"Common sense is in spite of, not the result of, education" - Victor Hugo (1802-1885)
