How to clean battery acid spill
ferndaleflyer
Need to clean off of slides before they are damaged by corrosion. Don't need them ruined by the acid spill.
17 REPLIES 17
ferndaleflyer
Not much changed color
John_Joey
ferndaleflyer wrote:
Did it yesterday with the CRC and it seemed to work well but I will do it once more later today. Don't want the slides ruined.
Glad youโ€™re happy with the results. So how much turned color on you.
Thereโ€™s no fool, like an old fool.
ferndaleflyer
Charlie_D_
Will get to it today---wonder if the CRC would be better than baking soda
Possibly. Since it has a colorant added to indicate acid I would think it would be a positive. Baking soda and other methods will work but how would you know if the acid is completely gone?
Enjoying Your Freedom?
Thank A Veteran
Native Texan
2013 Prime Time Crusader 330MKS
2018 Chevy 2500 D/A Z71 4x4 Offroad
2006 Holiday Rambler Savoy 33SKT-40,000 trouble free miles-retired
2006 Chevy 2500 D/A-retired
2013 Chevy 2500 D/A-retired
Sam_Spade
Charlie D. wrote:
although I did not give a ratio I did say to dilute first.
And now another partial quote.
That really makes no difference.
Even diluted some "caustics" are still corrosive and can produce toxic gasses when mixed with acid.
It is still NOT good advice.
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
ferndaleflyer
John_Joey
CDC cleaner
Charlie_D_
Sam Spade wrote:
Charlie D. wrote:
Any type of a caustic solution will neutralize the acid.
Some people say to use baking soda.
Sorry but that is BAD advice.
"Caustic solutions" often are corrosive too.
And they are more dangerous to work with.
And when combined with acid, they can produce toxic fumes.
THAT is why most people recommend baking soda.
You used only a "snip" of my post and although I did not give a ratio I did say to dilute first. Heck, in reality if you use enough water you wouldn't need to use anything.:)
Thank A Veteran
Native Texan
time2roll
pianotuna wrote:
rinse with water, apply baking soda in solution, rinse again.
+1 and for critical areas repeat three more times and then again in the morning.
wa8yxm
The first response is the best response
Bicarbonate of Soda (Baking soda) Sprinkle it. Mix it with water (As much as you can get to disslove) and spray it. wash the acid off with it.. When it no longer bubbles or fizzes. flush with clear water.> Tons of clear water (Well gallons).
While it is true ANY caustic soda will work Baking soda is safe. Non toxic and though you may need quiet a bit it won't damage the metal if rinsed off quickly.
Some other compounds.... Well in a science lab I might be able to tell you something like "1/4 cup in 10 gallons of water" of some such (NOTE nubmers are grabbed out of air and not even trying to be accurate) but too much is not a good thing.
bigred1cav
coke then water then repeat
2bzy2c
One word of caution - Don't get the baking soda inside the battery. It will then neutralize the battery.
My advice is worth exactly what you paid for it.
pianotuna
Nomad III
Nomad III
Regards, Don
BarabooBob
I agree with using baking soda. Make sure to rinse everything with large quantities of water.
Bob & Dawn Married 34 years
2017 Viking 17RD
2011 Ford F150 3.5L Ecoboost 420 lb/ft
Retired
