How to get at water pump in a Jayco Granite Ridge 3100ss.
dumboat2
Need to get to the water pump to replace. I know where it is located but cannot figure a way to get to it. Contacted Jayco and their suggestion is impossible. Looked for openings under the bed, in bathroom cabinets but found nothing. I am at a loss. Thanks in advance.
3 REPLIES 3
Deb_and_Ed_M
Wow. That's crazy placement - and for Ed and I, who winterize sometimes a few times in a season, a deal-breaker. I've always put a bypass valve on the front of our pump so we can pump antifreeze right from the bottle: we can winterize our Class C in under 10 minutes. I can't believe the manufacturers would make a critical process like winterizing, so difficult?
We open a basement compartment door, and the pump is right in front of our noses. And one more reason why we will NOT sell our Plain-Jane Class C...LOL!!!
Ed, Deb, and 2 dogs
Looking for a small Class C!
ericsmith32
On my Jayco it's under the bathroom sink. Have to take out the flash bottom in the cabinet. The tank is above the axle. Mine being a Escapade and yours a Granite I'd bet they're similar. I played where's that sound to find it.
2005 Jayco Escapade 28ZSLP (3500 Chevy chassis)
PapPappy
This is the second post today with a 31' MH looking for the water pump.
I believe your floorplan is similar to our Winnie., with our water tank and pump under the rear bed.
I had to lift the mattress off the platform....then remove the plywood at the rear of the hinge.
Here is what you will see.....at least in my RV.
I'm thinking of cutting out and installing an access door on the back of the MH, so that it's easier to access this stuff.:)
Bill & Claudia / DD Jenn / DS Chris / GS MJ
Dogs: Sophie, Abby, Brandy, Kahlie, Annie, Maggie, Tugger & Beau ๐Ÿ™‚
RIP: Cookie, Foxy & Gidget @ Rainbow Bridge.๐Ÿ˜ž
2000 Winnebago "Minnie" 31C, Ford V-10
Purchased April 2008:B FMCA# F407293
The Pets
