Apr-04-2016 10:07 AM
Apr-04-2016 02:30 PM
Apr-04-2016 02:29 PM
cbeierl wrote:
You shouldn't have to remove the hinge. Inspect the lower front and rear corners for a few screws holding the panel shut (instead of the latches all of the regular doors have). Removing those screws should allow the panel to hinge up. You will need to support it with a broomstick or something, however, since it won't have any gas cylinders supporting it.
Apr-04-2016 01:16 PM
Mandalay Parr wrote:yes apicture also would be a big help.
If you can't pull the hinge pin maybe drill out the rivets and reinstall.
Apr-04-2016 11:45 AM
Apr-04-2016 11:15 AM
Apr-04-2016 10:22 AM
