How to tell if coach is a wide body or not.
dtucker3usa
Can anyone tell me how to tell how to tell if a coach is a wide body? I have a 1997 Damon Intruder 352. The front tires are set 6 to 8 inches inside of the body itself. Does this mean I have a wide body with a standard P30 chassis or is the chassis considered a wide body too. I'm looking for suspension parts and they all say except wide body. Any help would be appreciated.
11 REPLIES 11
RLS7201
dtucker3usa wrote:
Any idea who sells suspension parts, anti-sway bar, stabilizer, etc. for a wide body?
Here is a great source for P30/P32 suspension parts. Robert Henderson still drives an old Chevy chassis.
Henderson Line Up
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
weathershak
rgatijnet1 wrote:
On the P series chassis, starting in 2000, Workhorse also had a narrow track and a wide track independent suspension which increased the wheel track of the front suspension.
X2 Mine is listed as a wide track. The front wheels are further apart than the P30 chassis. Coach is 102" wide also
Full timing it since July 2012
rgatijnet1
I'll bet that you have the narrow track chassis for 1997 and that the body measures 96" outside to outside. If it was the wide body, it would measure 102 1/2" outside to outside.
dtucker3usa
If the body is 8.5 ft, does that make the chassis a wide body too? Like I said in my original post, the tires are 6 to 8 inches inside of the body.
cruiserjs
How?? Measure it!!
Colorado Cruiser
Cruiser CF29CK 5th wheel; 2009 GMC Sierra 2500HD, 2wd, short bed
wonderful lifetime traveling companion/spouse
dtucker3usa
Thanks for all the info. When I've looked for parts it always says not for wide body. So I guess I can just ignore it and get the parts listed.
rgatijnet1
gbopp
The body is wider, not the chassis.
Triker33
Chassis on a wide body is no different then on on a narrow body.
So all chassis parts are the same.
google is your friend on finding chassis suspension parts, anti-sway bar, stabilizer, etc
Larry Full Time Since 99
1999 34Q Discovery DP ISB 275HP 6 Speed Allison
VMSpc | Pressure Pro
14 Lincoln MKS EcoBoost Toad
Click here to see where I am
dtucker3usa
Dutch_12078
If the body width is more than 96", it's a wide body.
Dutch
2001 GBM Landau 34' Class A
