HWH Air Leveling System went 'cold'!
goldenhawk9
Just got home from short trip and HWH panel dark. No button works. Can't turn on or activate 'dump' etc. Any ideas? It's on a 2002 Monaco Windsor.
3 REPLIES 3
goldenhawk9
JetAonly-That was the problem. Connector fell off. All good now. Thank You!
Also thanks Executive Dennis. Also looked in the front run bay and checked fuses. All OK. Didn't find reset button!
Executive45
Sounds like a blown fuse. Check your front run compartment for a reset button. It should be red about the size of a dime. Also, look on the backside of the compartment door. Monaco has a list there of all your hidden fuse locations.....Dennis
JetAonly
Pull the panel, there is a plug in that sometimes works itself loose on the back.
2000 Monaco Dynasty
ISC350
