A rise hitch is a drop hitch turned upside down.. I have a 13 inch one here.
8 inches is a LOT of rise/drop.. the problem with drop/rise hitches is torque on the cross member the receiver is welded to,, With that much rise you need to inspect the brackets and welds on that crossbar every time you tow.. I did not.. Thankfully safety systems worked better than designed.
