Oct-01-2013 01:06 PM
Oct-03-2013 05:50 PM
Oct-03-2013 11:42 AM
JimM68 wrote:
Things where you stick the ignition key in the side of the steering column do now ever have the actual switch there.
The key moves a rod up and down the column, and the actual switch is bolted to the side of the column under the dash somewhere.
/there are adjustments in the steering column that effect the movement of this rod.
It sounds like yours has never really moved far enough.
Oct-03-2013 11:35 AM
Oct-03-2013 09:13 AM
wolfe10 wrote:
Yup, relay is the same as solenoid, though solenoid tend to be rated for higher amps.
Oct-03-2013 05:03 AM
Oct-02-2013 07:33 PM
Oct-01-2013 04:39 PM
Oct-01-2013 03:53 PM
Oct-01-2013 03:49 PM
csburks wrote:
I have a 2001 Georgie Boy Suite on a Workhorse chassis that I bought new. About 7 years age it would not crank right after I made a stop on the road. They had to replace the ignition switch that is down inside the stirring column. At the end of last October the same thing happened and replaced it again. Last month I was having trouble cranking it and it was bad again. They have not determined what is causing it. Can you give me any help?
Oct-01-2013 02:44 PM
Oct-01-2013 02:05 PM
Oct-01-2013 01:42 PM
Oct-01-2013 01:31 PM
