Inside sewer smell
bob_b
My coach, a '06 Allergo Bus has begun to emit a sewer gas smell when flushing. I think that I need to replace those under-counter vents. What are they called and where to buy. Or, any other ideas? Thanks, Bob It's not the sinks as I stoppered and added water, no difference
bob b
8 REPLIES 8
dougrainer
1. The various air valves are connected to the GRAY system. So, flushing the toilet will not cause those valves to "leak" odors.
2. The most common sewer smell when flushing would be the rubber toilet seal on top the toilet flange.
3. Pour Pine sol in the gray tank and see if you get Pine Sol smell when flushing. This will narrow the cause down
4. IF you have a Clothes washer, make sure you have water in the washer P trap. Especially if you rarely use the Washer.
5. IF you are using Black Tank chemical(You SHOULD), then there should be no real smell coming from the Black tank.
6. Last, but I have seen this in Tiffins also, the 3 inch down pipe attached to the top of the Black tank from the toilet may have come loose or is NOT sealed and that will cause Black tank odor into the RV when flushing. The only way to check this is to pull the toilet, but if you need to check the toilet seal(item 2 above), then it is not a wasted effort. Doug
gbopp
Don't buy the cheapest one you can find. Spend a little more and get a good one.
azdryheat
You could also empty your tank and give it a good flushing. Perhaps put in some toilet chemicals.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
phil-t
Air Admittance Valve - Amazon
2014 Allegro 36LA
chuckftboy
Commonly called "studor vents" by the commercial plumbers around here.
2019 Horizon 42Q Maxum Chassis w/tag
Cummins L-9 450 HP / Allison 3000
2006 Jeep TJ and 2011 Chevy Traverse Tows
ssthrd
My wife calls them foo-foo valves...lol
Its called an Air Admittance Valve among other names. I would imagine that most RV or plumbing supply stores would have them.
Some screw on, others just slide on, so if you change yours, you might want to remove yours first.
2014 Keystone Laredo 292RL
2013 Palomino Maverick 2902
2018 GMC 3500HD, 4x4, 6.5' box, SRW, Denali, Duramax, Andersen
DeeBee, JayBee, and Jed the Black Lab
The hurrier I go the behinder I get. (Lewis Carroll)
CA_Traveler
Air admittance valve.
2014 Grand Cherokee Overland
Bob
Ranger_Smith
You can purchase them at Lowes or Home Depot. They're about $8.00 each. They have them with a male and female thread so get the correct ones.
Where we are now
Amateur Radio Operator WW1SS . . . Flex 6500 PGXL and TGXL
Steve and Joy
2014 Itasca Suncruiser 38Q . . . 2016 Lincoln MKX
The Doodles, Abbie & Abel
Baby and Kissie the Chihuahuas and Lucy the Biewere Yorkie
