Installing laminate wood floors
jtad
We have been talking about replacing the carpet and tile in our 2004 Holiday Rambler since we bought it last Feb. When we were looking at coaches we asked a couple of different places about doing the install. I don't remember what the quotes were but they were in the thousands. When I'm done I will have less than a $1,000 in the whole job. I'm pretty handy, have done a lot of tile work and have put down a laminate wood floor about a year ago in a cabin. So I thought I'd give it a shot... Carpet tear out wasn't bad, but the tile demo was a beating..Here are a couple of pics the last one is just a preview of what we are putting down. I will add some more as I go..
2004 Holiday Rambler Endeavor 40DST
67 REPLIES 67
msmith1199
mike brez wrote:
IMHO I would rather have tile and carpet. I'm not a fan of laminate wood floors.
It's not a wood floor. It's a laminate.
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
Naio
diplomatdon wrote:
The laminate will look nice when done, however I always found laminate to be noisy and cold. All tile and no heated floors cold and hard. I did my 2001 Diplomat with lock and click cork. Installs the same as laminate, rich looking, warm to walk on, easy to clean...galley and bedroom with cork, quieter from road noise and so nice to walk on due to the cushiony feel and warmth.
I always forget about cork! Soft is nice. I have this fear that kitty would use it as a scratching post, though. Do you think that is possible?
3/4 timing in a DIY van conversion. Backroads, mountains, boondocking, sometimes big cities for a change of pace.
Kayteg1
If you are asking me - marble is self-edging as you have solid material at 3/8" thickness.
You can cut it, shape it any way you want and I only lacked patience to repolish the edges.
With ceramic tiles you are not only very limited with shapes, but any scratch will score ceramic layer and expose clay under.
bbaker2001
pretty cool job, is tile difficult to cut cornors
BB from California
2015 Ram 3500
2001 Cardinal
best friend is my wife ๐Ÿ™‚
Kayteg1
In our vintage coach I instill about 500 lb of marble floors and love it.
Can't imagine anything but marble on curvy stairway.
We hate the carpet we left in master bedroom, while living rm laminate gets rug drop over it.
Good to have choices.
lafrentz
lenny-shawna wrote:
Jtad,
I too am not a fan of tile or carpet in an RV. Tile is very heavy and do to the perpetual motion of driving, is susceptible too cracking. Chipping is another problem that warrants concern; even high end porcelain chips. And yes I've dropped objects on my tile and chipped it.
Carpet, well not many positives there so I'll leave it alone.
I like glued down engineered wood. I would also glue in-between the joints to make it highly water-resistant. I installed this in my home and a couple years later had a pipe break and flood the floor. We though for sure the floor was ruined. Fast forward 4 years and still the floor looks beautiful with ZERO water damage. I attribute this to the fact that the wood was engineered and I glued both the wood to the floor and the joints.
Since you have an RV and are going over a wood substrate I would first install a water barrier and install over that.
Good luck!
tile weight makes no difference in a DP nowadays.factorys have it now as standard flooring.Todays tiles do not chip or crack like the old days with special underlays and the new super thinsets available
all mid to upper end Class A All use tile flooring.Engineered hardwood is cheap flooring and marks very easy and hard to repair it
you don't see it coming from the factory.some people use it to repair old units which works well
tinkerer
Last summer I installed Allure in our coach,replacing the carpet. After spending time in our state and 3 months in Arizona, we are very happy. Make sure you float it and leave a small gap on one side to allow ffor expansion.
lenny-shawna
Jtad,
Good luck!
lenny-shawna 2011 Winnebago Tour 43'. Cummins 450. Freightliner Custom Chassis. Hydra-lift motorcycle carrier 2014 Harley Ultra Limited. 2012 SRX. With our 3 Beagle/Hounds
prstlk
Any input as to floor heat? Understand it's a pretty easy add on for new floors regardless of type.
Thinking of replacing my flooring input appreciated.
2007 Keystone Challenger 5th wheel, Ford F350 Super Duty 6.7L Diesel, Short Bed, 2 dogs and the cat and rolling down the road full time since May 2014
Naio
Looks great!!
I test drove a van the other day, and the current owner had put in laminate. I decided I am going to put it in whatever new van I buy, whether or not it is his.
Carpet is completely impractical for my camping style :).
diplomatdon
The laminate will look nice when done, however I always found laminate to be noisy and cold. All tile and no heated floors cold and hard. I did my 2001 Diplomat with lock and click cork. Installs the same as laminate, rich looking, warm to walk on, easy to clean. I didn't remove tiles in the galley area but may replace them with porcelain tile as stronger than ceramic and not so prone to cracking and breaking from the rollers. Rollers in the lounge area are mounted to the floor and the slide rolls on top of them. Galley rollers mounted to the slide and roll on the tile, which has caused breakage. galley and bedroom with cork, quieter from road noise and so nice to walk on due to the cushiony feel and warmth. How were you able to remove tiles under the cupboards in the slide. Did you have to remove some of the cupboards?
derouen6
Hey John,
We installed laminate in our Tropi-Cal you didn't buy. It looked great and we loved it as I am sure you will in your MH. Good luck. Can't wait to see the finished pics.
Sherry
wirenutz
let us know how the slides move over the new flooring
2007 All American Sport Toy Hauler 38 foot, 14,400 LBS dry weight
1999 Four Door Freightliner,new 6 Speed Auto, new Cat Motor, 12,600 LBS, rear air dump, lowers rear by 3", air activated rear locker, air ride seats, air ride cab, air ride suspension
crasster
For me, tile or vinyl planking. "waterproof" is important.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
lafrentz
me neither In my current MH I went with glue down Vinyl plank in bedroom and bedroom slide.Tile in the main area and 3/4 Hardwood on living room slide. I hate carpet in a MH
