installing solar panels without drilling holes
rdrv831
I am considering using the following mounts to attached a solar panel to my Class C RV with a rubber roof.
Instapark ZJ03W Drill-free Solar Panel Roof Corner Mount Rack Bracket Kit NEW
And
Instapark ZJ04W Drill-free Solar Panel Roof Mount Rack Rail Bracket Support Kit
Example installation from
RV solar system DIY
Question I have is with a rubber roof that is basically glued down, is their any issues with gluing these mounts to the rubber roof?
Will this work on a rubber roof?
Thanks
Ray and Maria
Lincoln CA
Family Photo's link
10 REPLIES 10
Crabbypatty
I just installed over rubber a nd used a bracket with lots of Dicor and screwed into the roof. I woudnt glue to a surface that can be peeled off.
John, Lisa & Tara:B:C:)
2015 F250 4x4 6.2L 6 spd 3.73s, CC Short Bed, Pullrite Slide 2700, 648 Wts Solar, 4 T-125s, 2000 Watt Xantrax Inverter, Trimetric 2030 Meter, LED Lights, Hawkings Smart Repeater, Wilson Extreme Cellular Repeater, Beer, Ribs, Smoker
RVWithTito
Crabbypatty wrote:
I will be installing solar soon on my epdm rubber roof. I am not concerned about leaks. Already I have installed a ladder and utilize Dicor Lap Sealant. Works perfectly. I will be doing the same. I am going to attached the mounts to the panels first and apply sealant to the bottom of mount then place the panel on the roof. Now fasten with a screw gun through the hole oozing in sealant. After apply more sealant over the top. This way sealant is under the bracket and also follows the screw into the hole. The Dicor self levels and makes for a nice neat waterproof install.
Agreed. Dicor is your friend. Don't be afraid to add a few new holes in your roof if you have to. Just seal them up properly as noted and check them a few times a year.
2007 Four Winds 31F Class C; Ford E450 Chassis; 250 Watts Solar;
RV Solar, Towing, DIY and Tips on my website RVwithTito.com
Watch My Video Tips at YouTube/RVWithTito
Crabbypatty
DrewE
I would not go with mounts glued onto a rubber or similar membrane roof. The glues used to hold the rubber down on the wood are not super strong, and localized pulling such as a panel might produce when driving or in windy conditions could easily tear it away from the wood (or tear holes in the rubber).
As with the others, I would strongly prefer a mechanical attachment (i.e. screws or similar), of course with appropriate sealants.
pconroy328
He didn't say he was afraid. Geebus. He asked if anyone had any thoughts.
OP did you see the Amazon Reviews?
Not so glowing.
2oldman
pigman1 wrote:
Your links don't work
I think his links are the same as those pictures.
Golden_HVAC
Why are you concerned about holes in your roof? Do you think that the manufacture built your RV without any holes in it?
Just put in normal brackets, and use rubber roof sealant, and they will not leak. I installed mine back in 1996, and still no leaks. Sure I coated the roof when it got to 11 years old, but no leaks there. The skylight started leaking, but was fixed by coating the roof.
Good luck,
Fred.
Money can't buy happiness but somehow it's more comfortable to cry in a
Porsche or Country Coach!
I havn't been everywhere, but it's on my list.
Kangen.com Alkaline water
Escapees.com
pigman1
Your links don't work.
I don't know why folks panic about drilling a hole in the roof. We have 6 panels with 8 fasteners on each panel drilled into the roof so the panels can be raised on any axis. Current sealers are excellent. Just use them.
Pigman & Piglady
2013 Tiffin Allegro Bus 43' QGP
2011 Chevy Silverado 1500
SMI Air Force One toad brake
Street Atlas USA Plus
tpi
I have strong metal roof and I used 3M 5200 to glue panel down on 8 mounts. But even there, the decision was controversial..had strong advice both ways.
With the rubber roof I'd strongly suggest screwing them down and caulking.
2oldman
I wouldn't consider that. You're gluing these mounts to a membrane that's just glued to wood, and sometimes not all that well.
Don't be fearful of drilling your roof. There are a lot of holes there already, and, with proper caulking they will never leak and be a good solid foundation for panels.
