Is my BIRD working?
cvbdsl
OK, so my chassis batteries keep going down, even when plugged in.
When I run the genny they do not charge, when I run the engine they do charge.
When plugged in I do not hear any clicking from the BIRD (as some state they do) even when the chassis batteries are down.
I'm thinking of ordering a new BIRD but it looks like a PITA to change it, a large red power cable runs right tight over it.
Its either the BIRD or the relay - a quick look the other day seemed to show fuses on either side of the relay (MH not in a good location to really see - am moving it). Are there fuses on either side?
2008 Holiday Rambler Scepter 42 PDQ
2018 Ford Edge SEL- Ready Brute Elite Tow Bar/Blue Ox Base plate/Patriot Brake System
Retired Canadian Army WO (1971-2000)
22 REPLIES 22
cvbdsl
holstein13 wrote:
Newmar no longer uses the BIRD. Now they use a BIM, Battery Isolation Manager.
Any idea if it backwards compatible (e.g. can I swap it in for the BIRD)? If I have to replace it, might as well use the latest technology?
Thanks
Chris
holstein13
2015 Newmar King Aire 4599
2012 Ford F150 Supercrew Cab
cvbdsl
Actually the transfer switch is something else - mine is made by Iota and they tend to catch fire (happened on my 99 DSDP). I know, I had to buy a new one after it melted. Got the pictures on a different forum - easier posting pictures there than here.
The transfer switch is (in mine anyhow) a black plastic box that switches between the generator and shore power (after a pre-set delay). It does not switch between house and coach batteries. Two totally different systems (12 volts vice 120 volts).
Chris
gbopp
Big Katuna wrote:
Commonly called a transfer switch.
Now it makes more sense.
Big_Katuna
My Kharma ran over my Dogma.
newman_fulltime
I was hoping to see a parrot working :B
cvbdsl
Thanks, I didn't think of checking the ground:o!
BIRD = Bi-directional Isolator Relay Delay
It is the device that is supposed to switch between charging house and chassis batteries.
Chris
dverstra
I'm not sure what a BIRD is but on my coach, when the module that was supposed to charge the chassis battery didn't work, it was a ground wire that was loose.
Life's journey is not to arrive at the grave safely in a well preserved body, but rather to skid in sideways, totally worn out, shouting "...Holy Cow....what a ride!"
2007 Holiday Rambler Navigator
2013 Honda CRV
Returned Peace Corps Volunteer - Sierra Leone
