J1939 plug for VMSpc
Billdreamlv
We have a 2006 Allegro Bus Cummins 400HP. Does anyone know where the J1939 plug is located on the engine for a VMSpc Silverleaf engine monitor Jib. And what kind is it. How many pins and size.
Bill and Mary 2006 Allegro Bus AOD monitors Windows 8.1 crossroads navigation Jeep Grand Cherokee toad
6 REPLIES 6
fcooper
DSDP Don wrote:
Bill...Once you start running the VMSpc program, you'll never drive your coach again without it running. I run my on a small notebook computer to the left of dash. I can see the big gauges and no exactly what my coach is doing at a glance.
I can watch my rolling mpg and actually make changes to my driving by seeing the mpg change. When I pull into get fuel, I check my fuel used and know within a couple of gallons how much I'll take.
X2. More info than what your dash instruments provide.
It will run on windows based tablets also if you're limited in space. My old tablet is still running windows 2000 and vmspc. Ebay is a good source for used windows tablets.
Fred
Fred & Vicki
St. Augustine, Florida
DSDP_Don
Bill...Once you start running the VMSpc program, you'll never drive your coach again without it running. I run mine on a small notebook computer to the left of dash. I can see the big gauges and no exactly what my coach is doing at a glance.
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
Billdreamlv
Thanks guys. Found it right where you said it would be. Now I need to convince myself that the VMSpc is the way to go.
Teacher_s_Pet
Just left of the steering wheel just below the dash, it has a gray twist off cap 1ยฝ"-2" in diameter on our Phaeton.
'06 Phaeton 40' QSH
'14 Ford Flex SEL AWD Toad
'04 R-Vision Trail-Lite 213
Scottiemom's Pet or husband to Dale
RV.net Rallies 13, Other Rallies 21, Escapades 7
Fulltimers since 2005, Where are we?
Our Travel Blog
mci7
On my Foretravel, it is located on left side wall in front of knee under dash.
No longer able to drive with out it, only thing on dash now is the air pressure gauges, everything else is on the VMSpc, much more info than I ever imagined.
Dave M
Dave M
Central Virginia
Had MCI Conversion 20+ yrs
Presently 2001 Foretravel w/ISM500
Usual Toad 2004 F150 Ford w/Can Am 800 Max
chastho
On my 05 it is under the dash behind the steering column, hard to find but it is there. I don't remember the number of pins but if I can find the info I will post it. Mine was a grey round and had a cap on it.
