โAug-07-2015 05:28 PM
โSep-08-2015 04:30 PM
JackMS wrote:Yes, not only does it work, but it's fully supported by PowerSpec tech support at Cummins. When I had a driver problem, Cummins logged into my computer and updated my flash memory in the inline 5 and made sure it all connected to my engine. They were very helpful.
Good to know powerspec works with inline 5. The powerspec website i saw says you need inline 6 which is much more expensive.
โSep-08-2015 04:02 PM
โSep-08-2015 11:41 AM
โSep-02-2015 12:47 PM
NeverHome2 wrote:I'll find out soon enough. I went ahead and ordered the interface kit for the engine port and ECM. I'll download Cummins powerspec program when I get it and see what I can change.
Holstien13, When we first got the coach I took it to Cummins for reprogramming. They found that the program didn't change the way it operated so they called Holiday Rambler who said that it is wired to operate the way it is.
I called HR to get a wiring diagram and ask for help. They said they could not tell me how to change it for safety/legal reasons and the diagram they sent was a point to point wire map not a ladder/logic diagram so it is hard to figure out. It remains the way it is.
โSep-02-2015 07:50 AM
โAug-18-2015 06:16 AM
Mr.Mark wrote:
On our previous coach (Dynasty), I used it whenever we started to coast too fast and also to slow down in normal traffic. The cruise would not work if the jake was turned on so I kept it off until I needed it. The Jake would kick off at about 20 mph or so and then you had to use the service brakes.
We have a 6 speed retarder on the new coach.
MM.
โAug-18-2015 05:28 AM
NeverHome2 wrote:What engine do you have in your HR? If it's a Cummins, you can probably reprogram the settings for the Jake Brakes and cruise control using Cummins PowerSpec (available for free to all owners).
Computers introduced cruise control that worked with the Jake and would automatically start the Jake and control your speed to 5 mph over setpoint of the cruise. I so wish my motohome worked the same way. Our HR turns off the cruise when you turn on the exhaust brake and when you turn off the exhaust brake you have to reset the cruise. Never have I seen anything so stupid.
โAug-17-2015 07:05 PM
DSDP Don wrote:
"creeper".....I give up! Between the two posts on this subject, you appear to be the only one that just doesn't get it. Just can't fix that!
โAug-17-2015 06:04 PM
โAug-17-2015 10:17 AM
โAug-16-2015 06:34 PM
DSDP Don wrote:
"but you can also polish the brakes by applying them lightly on a regular basis.
Your engine/exhaust brake typically drops off at 15mph. Since most RVer don't rush up to signals, they need very little braking to slow the coach to a stop or slow roll after getting down to 15 mph.
Many think they're saving those expensive brakes when they're really lightly glazing them.
The repair is a high speed run with a few hard stops. You can also use emory cloth to clear up this type of light glazing.
The high heat glazing that you're speaking of takes rotor/drum turning and shoe/pad replacement. There are levels of glazing!!!!
DSDP Don wrote:DSDP Don, I thought that polished brakes are exactly what rotors are supposed to look like. Correct me if I'm wrong, but every single disk rotor I've ever seen on every single car has polished rotors with concentric small groove marks when they are used. On my home vehicle, it gets rusty when I don't use it for a while, but after a trip out, it returns to a normal relatively mirrored polished finish. Frankly, I don't see how it's possible for the rotor to look any other way unless there is some serious metal on metal scratching going on.
"Creeper"....It's lovely that you drive the mountains and know all about heat glazing, but you can also polish the brakes by applying them lightly on a regular basis. Your engine/exhaust brake typically drops off at 15mph. Since most RVer don't rush up to signals, they need very little braking to slow the coach to a stop or slow roll after getting down to 15 mph. Many think they're saving those expensive brakes when they're really lightly glazing them. The repair is a high speed run with a few hard stops. You can also use emory cloth to clear up this type of light glazing.
โAug-16-2015 05:48 PM
โAug-16-2015 11:57 AM
WILDEBILL308 wrote:
This is true Glazing is more associated with over heating. I haven't heard of anyone wearing out their brakes on a diesel pusher.
Bill
