Knight pdq slideout maintenance
aihchris107
I have a 2011 Monaco Knight 40 PDQ with 4 slideouts The manual does not give any info on slideout lubrication.Should I lubricate any of these mechanisms
5 REPLIES 5
DSDP_Don
Duplicate Post
Don & Mary
2019 Newmar Dutch Star 4018 - All Electric
2019 Ford Raptor Crew Cab
DSDP_Don
I use a silicone spray once a year during maintenance. The spray can be used on tow bars and the slide gears. Roadmaster sells a specific spray and so does Camping World. I also use a spray foam designed for the slide seals once a year. I spray it on and wipe it off.
Don & Mary
manfromnc49
I have just gotten a 2008 Four Winds Hurricane with 3 slides and I have the same question. I have heard about the baby powder along the rubber seals. Which I've done.
But, I am wondering about the gear mechanisms. What should I use, how and how often? Thanx as always for any help. Michael
lanerd
It's my understanding that simple swipe with a cloth that has baby powder (or other similar powder) is sufficient. There is also an airasol dry lubricant that will do the same thing.
I do mine twice a year with the can.
Ron
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
1492
Moderator
Moderator
Moved from Forum Technical Support
