Dec-30-2018 03:45 AM
Dec-31-2018 12:17 PM
Dec-31-2018 11:50 AM
toedtoes wrote:
My disagreement was with the idea that an owner who puts their rig under cover cares more and checks it out more frequently. Many owners will put it under cover and not look at it until the next season - that is not caring for the RV more than a person who stores it outdoors and checks it after every rain, etc.
Dec-31-2018 08:16 AM
Dec-31-2018 07:07 AM
Dec-31-2018 02:00 AM
T18skyguy wrote:toedtoes wrote:T18skyguy wrote:
As a buyer, look first to sellers that have their rig covered, and these folks probably also inspect regularly cause they care.
Not always true. There are many posts from folks who put their RV under cover and then never bothered to look at them until spring only to find a leak had destroyed the rig.
The ideal owner does regular maintenance to prevent leaks, checks out their rig throughout the rainy/snow season regardless of where it's kept to identify any leaks early, and takes action to stop any leaks as quickly as possible.
However, no matter how on top of things a owner might be, there is always room for a leak to happen - whether the owner got ill or injured, there was a death or divorce in the family, or maybe just got caught up in work... Sometimes life gets in the way.
I have found that a roof vent leak is an easy fix. If the owner catches it early (which is usually easy to do because it's right in the open), then it may show a small water stain still but had been dealt with promptly and effectively with some basic caulking.
A leaky seam or window is different. The water is more likely to have drained down the side of the RV, doing additional damage along the way. It's harder to see because you have cabinets, beds, couches, etc., blocking your view of the leak and so it goes longer before detection. And repair is a lot more involved.Not always true. There are many posts from folks who put their RV under cover and then never bothered to look at them until spring only to find a leak had destroyed the rig.
If that's true I would like to see their cover. Some folks put a few pieces of tin up and call it good, when it's very little protection from sun or blowing rain. Another possibility is they had a major leak in progress during a trip, didn't notice it, put the rig under the cover, and discovered it later and said the cover was inadequate. I have a 32 foot rig under a 40x14x12 foot cover, full back and full left side enclosed, and halfway down the right side. The rig sits 8 feet in and I've had a few drops blow on the front but that's it Nothing on top ever.
Dec-30-2018 09:38 PM
Dec-30-2018 07:12 PM
MDKMDK wrote:
Agreed. Build quality, roof material/design, and maintenance are the issues that affect whether or not a particular roof will leak or not.
Dec-30-2018 10:11 AM
Dec-30-2018 08:50 AM
Dec-30-2018 08:11 AM
the RV should be stored (not used) out of the sun and rain.
Dec-30-2018 07:40 AM
Dec-30-2018 07:29 AM
Dec-30-2018 07:28 AM
Dec-30-2018 07:11 AM
theoldwizard1 wrote:
I don't think it exclusively a Class C issue. Very few, it any, RVs will live a long time without a leak.
There are a lot of reasons, but they all come down to build quality. The "rubber" (EPDM ?) roof material that is most commonly used is NOT impervious to sun. For maximum life, the RV should be stored (not used) out of the sun and rain. If not possible, the rubber roof should be washed with mild soap 2 - 4 times a year and then a light UV protectant (like 303®) applied.
The "ultimate" roof material is either fiberglass (which must be painted to prevent UV damage) or aluminum. Both are much more expensive to install, but require less maintenance and will live much longer.
Any roof penetration, seam, or roof to side seal is also a common source of leaks. Applying more and more sealant is not the best solution. Removing and replacing the sealant is better, but is difficult, especially getting ALL of the old sealant off without damaging the rubber roof.
