โNov-16-2017 12:24 PM
โNov-18-2017 09:33 AM
โNov-18-2017 09:24 AM
wolfe10 wrote:. Thanks Wolf, I was able to find and read the PN on the other end of the line where it attaches to the joy stick manifold. It is AP 2464, not sure where the R came from in Budโs chart.
Price on the whole hose is WAY out of line. Check with HWH for parts price. PN should be on both ends of the hose.
โNov-18-2017 06:14 AM
Gjac wrote:dougrainer wrote:That is a nice tool, it looks like you can use it without removing the whole hose, is that true?Gjac wrote:dougrainer wrote:I called a Hydraulic shop yesterday and asked about adding a splice fitting where the line was chaffed through by the frame, and what they described to me was a junction fitting that screwed into the cut line with a retaining nut to secure it. They said it works well with Parker hoses. It was about $30 for the fitting and about $200 for the complete line. They could not install it on the MH so the line would have to be removed anyways. Is this what you are describing? Is there a name for this fitting I can give them?
HWH pumps run at 2900 to 3200 PSI. You do NOT have to replace the complete line. IF the Shop has a tool(I do), you can install the metal flare ends on the end of the bad hose in front of the damaged area(cutting out the hose from the jack to the damaged spot) and then just make a short hose to go from the original to that Jack. Saves time and money. Doug
No, I have a portable Hydraulic Swagging tool I purchased from HWH 25 years ago. The Metal ends are installed exactly like HWH installs them. HWH no longer sells that tool. There is nothing wrong with cutting out the bad spot and swagging a new fitting on the old hose and making a new hose for the length from the Jack to the bad area. Your other hoses are the same age as the bad one. You going to replace those also? If you follow the thread about NOT using the good part of the old hose. If it was a front Jack, I would replace the complete hose from the jack to the Joystick. The Swagging tool allows me to make HWH hoses to whatever length I need. Doug
This is the tool
http://www.hwhcorp.com/mr751000.pdf
โNov-17-2017 12:35 PM
โNov-17-2017 12:33 PM
This is the tool
โNov-17-2017 11:30 AM
โNov-17-2017 11:29 AM
Bud
USAF Retired
Pace Arrow
โNov-17-2017 11:06 AM
enblethen wrote:I found a barely readable label wrapped around the hose by the jack. It looks like Part# AP2464 and Hose assy .25 X something. I hope the something wasn't the length. Does the part # look familiar? On edit there must be a R in front of the AP I just found it in the list you posted.
Did you find the number on the white label? That will help. The person answering the phone can normally place the order with the part number.
โNov-17-2017 10:24 AM
Bud
USAF Retired
Pace Arrow
โNov-17-2017 10:05 AM
Bud
USAF Retired
Pace Arrow
โNov-17-2017 10:04 AM
enblethen wrote:Thanks Bud, just called HWH but they put me on a call back list.
That is way too much. the built line was under $50 in Montana.
A 156 inch line from HWH was $67.
I would not repair a line even at your ig's age and mine are older.
See what HWH wants.
โNov-17-2017 09:58 AM
mike brez wrote:The trip back was harrowing at first there was 5 ins of snow on the ground and MH when I got there. I practiced driving in the parking lot just to see how the MH would handle and stop in the snow, it actually did well. My wife was nervous the whole way back. The major highways were clear and the snow on the trees was beautiful, saw 5 bald eagles, several coyotes and foxes and herds of deer sometimes 30 or 40 at a time out in the fields. The temps were extremely cold so we stayed in motels each night. Had to block the front grill with cardboard to get the engine to come up to temperature. The old 454 started each morning even in 4 degree weather. The only other problem was a vibration in the seat after 60 mph. I was jacking the rear tires off the ground to check for out of roundness when the rear hose let loose. Other than that we made it back OK. After driving 2000 miles through cold and a few snow showers I would no longer be worried about winter travel but my wife would.
Hey Gary a buddie of mine worked HERE for years before moving to NC. They are in Bridgeport. Not sure if they can help any.
I take it you are home? How was the trip back?
โNov-17-2017 06:43 AM
โNov-17-2017 06:11 AM
โNov-17-2017 05:18 AM
Bud
USAF Retired
Pace Arrow
