leaking toilet
johntraveler
I have a 2000 Georgie Boy Landau. There is water leaking around the base. How do I remove toilet ? Thanks John
3 REPLIES 3
Old-Biscuit
Turn water source off
Disconnect water line at toilet
Remove hold down nuts on toilet base....you may need to remove outer shroud on toilet base to access the nuts.
Lift toilet up off floor flange.
1492
Moderator
Moderator
Moved from Forum Technical Support
harold1946
That depends on the make and model. If you know those two things, go to the manufacturers website and you will find instructions and part numbers, probably in down-loadable PDF format.
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer Sport toad
