two travelers wrote:
I'm thinking about relacing the incandescant tail lights with LED's on our Winnebago Sightseer with F53 chassis. I've heard that since the LED's have a lower resistance, that it play's havoc with the cruise control. Has any one done this replacement and are there any issues that I need to consider? Any LED bulb repalcement suggestions? Thanks!
two travelers,
First off, I'm not sure who's told you that there's related problems with cruise control performance with the use of LEDs for tail lights but, it's a bit false. There's a zillion cars/trucks/motorcycles/motorhomes and more that folks have switched to LED tail lights and never have a problem. And, while I'm certainly no electrical guru when it comes to much of this stuff, I've always been lead to believe that there's LESS resistance to an LED bulb and, that's the exact reason that, one of the only problems that crops up when one changes to the use of them for tail lights is, the turn signals go nuts.
That is, they flash considerably faster due to the fact that there's way less current being drawn and, they, the LEDs don't provide the resistance that the flashers need to see, in order to function correctly. That is why, in many cases when folks change to LED tail lights, they have to add resistors to bring up the amount of resistance the flashers need to see, in order to function correctly.
Now, in many of todays "complete" LED tail lights, some of that is already done. When I say complete, I mean purchasing an entire tail light assembly, not just a bulb. I changed the entire tail light assembly on our '04 Jeep Rubicon a few years back and, while the lights were considerably brighter than the stock incandescent ones, the stock flasher went crazy. Those tail lights flashed at over twice the rate of speed than they did with the old bulbs. I purchased some "in line" resistors that were just "plug and play" units and, the flasher functioned normal after the install of those.
But, that was a while ago and, while I've change almost all my interior lights, my compartment lights, porch lights etc. over to LEDs, I've not changed my current coach tail lights to LEDs. I'm leaning towards it but, just haven't gotten around to it yet. Soon.
Scott
Scott and Karla SDFD RETIRED2004 Itasca Horizon, 36GD Slate Blue 330 CAT
2008 Caliente Red LVL II GL 1800 Goldwing KI60ND
