Let Me Know if You Have Allison Transmission Fluid Questions
hzjcm8
Hi all,
I've just joined Good Sam Club. I was the former Transmission Fluids Engineer at Allison Transmission. I held that position from 1990 until my retirement in 2009. Let me know if you have questions about TranSynd, the TES-295 specification or just anything to do with automatic transmission fluids. I'm here to help.
Tom Johnson
Former Transmission Fluids Engineer (Allison Transmission, Inc.)
Avon, IN 46123
237 REPLIES 237
hzjcm8
Glenn Cooper wrote:
Tom, thank you for ALL your help!
Now I have a Allison 1000, in my 02 Winnie purchased new by me.
And I changed the fluid twice within the first 5/6 K miles,
fluid and filter. Then about 5 yrs ago I changed the spin on
filter, just because I had it and NEW fluid.
Do you recommedn I change all the fluid twice again?
I have 45 K on the MH at this time. Thanks for your input! coop
Coop,
What fluid did you install when you changed the spin-on and installed new fluid 5 years ago? Was it TranSynd or another TES-295? If you installed TranSynd (or another TES-295 fluid) then you should be good for 150,000 miles on that fluid and 50,000 miles or 24 months on the spin on filter. If you're running TranSynd or another TES-295 fluid then I'd just change the spin on filter at 50,000 miles.
Hope this helps !!
Tom Johnson
Avon, IN 46123
Jarlaxle
hzjcm8 wrote:
Hi all,
My Genesis has an MT643 trans behind a DT466 engine...Dexron III, right?
John and Elizabeth (Liz), with Briza the size XL tabby
St. Bernard Marm, cats Vierna and Maya...RIP. 😞
Current rig:
1992 International Genesis school bus conversion
wny_pat1
bobschultz wrote:
Have a 2000 DSDP with an Alison MD 3060 trans. Been reading the forum re. Transyd. Called Allison and spoke to a Tech. Told him with the high cost of fuel I will only be driving a few thousand miles a year. Do I really need to change to Transyd. He said that the Dextron III was ok to use. I changed the fluid and used the high cap. filters. Found Valvoline Dex III at Napa. Bob S.
With Transynd, your transmission will run cooler, not be affected by seasonal temperature changes, and last much longer that it will with the Dextron! Plus you will not have to change the fluid anywhere near as often when running Transynd. With Transynd, you can probably go years between changes provided you change the filters at the recommended interval and have the Transynd analyzed at the same time. The analysis will tell you if the Transynd has any contaminates in it.
“All journeys have secret destinations of which the traveler is unaware.”
bobschultz
J_Walker
hzjcm8 wrote:
If anyone thinks there are other Good Sam Club forums that should be getting in on these Allison related posts, please invite them to drop in and ask their questions. I'm here to help where I can!!!
Tom, The other biggest forum is IRV@. Maybe you could post there.
Jim Walker
2014 Thor Palazzo 33.2, 6.7 Cummins, 2100 Allison
2009 Malibu
hottubkid
From what I have just read the filter should be changed at the first fiveK which I did but then it is 50K for the next time unless it is the atificial trans fluid. This that is what everyone agrees with
hottubkid60193@yahoo.com
2004 SOUTHWIND 36E Tow 2003 CRV
Glenn_Cooper
frankfish
FWIW, until retiring in 2008, I spent most of my career as a mechanic/service manager/shop owner. My take on fluid changes is simple. Fluids are the lifeblood of engines and transmissions. They are responsible for lubrication and heat removal. They break down and get contaminated over time, which makes them less able to do their job.
How much do you pay each year for insurance on your MH? Probably more than the cost of changing all your vital fluids. My bottom line = regular fluid changes are the best and cheapest insurance that you can buy.
hottubkid
Thanks I'm at 48000 and from what i have recieved I will need to change filter and fluid at 50000. Coach is getting tires but hope it is markes as to which fluid is in it or on the paperwork in the coach. I know it is a 1000 but have no idea which fluid is in it and am learning which to buy for it. thanks for the help
hzjcm8 wrote:
Hi all,
hzjcm8
If anyone thinks there are other Good Sam Club forums that should be getting in on these Allison related posts, please invite them to drop in and ask their questions. I'm here to help where I can !!!
PS: I'm headed for bed. Everyone have a nice night and don't forget your prayers. Be safe !!!
Tom Johnson
Avon, IN 46123
hzjcm8
supercub wrote:
I just purchased an 05 Fleetwood Revolution LE Cat 400hp and Allison Transmission. It only has 9200 miles on it. I have no idea what has been done to it as far as mainteance. Any recommendations on what kind of servicing I should have done? Thanks
Brian
Supercub,
Is your name from flying a supercub? I have a pilots license but only fly the Microsoft Flight Simulator now .... too old; don't trust myself with ATC. I could still handle flying but the ATC rules might get to me.
Since you don't have history on the fluid, I'd recommend a fluid analysis to determine the condition and let me see the results. I'll give you my recommendation based on the results. Or, you can just do a refill with TranSynd, drive it around for 30 minutes, drain again install new "high capacity" filters and then refill again with TranSynd. Then you're good until the next filter change.
Tom Johnson
Avon, IN 46123
lanerd
Humm.. I thought I answered, but I don't seem to see it anywhere. So, Tom... thanks for the info. I will have the fluid analyzed in three years and go from there.
thanks again
Ron
Ron & Sandie
2013 Tiffin Phaeton 42LH Cummins ISL 400hp
Toad: 2011 GMC Terrain SLT2
Tow Bar: Sterling AT
Toad Brakes: Unified by U.S. Gear
TPMS: Pressure Pro
Member of: GS, FMCA, Allegro
RETIRED!! How sweet it is....
hzjcm8
ArchHoagland wrote:
It's my understanding that the diesel electrics in train locomotives never change their engine oil. They have a filter that is quite large and it gets changed but not the oil.
Could you shed some light on this?
ArchHoagland,
This could be possible but I'm not sure if it's true or not. I'll have to look into it for you.
Tom Johnson
Avon, IN 46123
ArchHoagland
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
hzjcm8
lanerd wrote:
hzjcm8 wrote:
lanerd wrote:
Welcome Tom... my 08 Safari has the C7 CAT and a 3000mh (built in 07) Allison and as I read in an earlier post (and also in my Allison manual), I'm required to change both filters every 36 months and full fluid change every 48 month. When changing the filters, I will lose almost half of the fluid and am required to replace it (of course). When changing the fluid at 48 months, I assume I do not change the filters, but if I don't pull both filters I also assume I will not get the entire 19 qts (4" pan) to drain. I now have 27,000 miles and recently replaced both the filters and the 19 qts of Transynd. It seems strange to me that the filters are only good for 36 months and the fluid for 48. Will it be detrimental to the trans if I change both filters and fluid every 48 months, or should I change both every 36 months? Due to the price of Transynd, I would like to reduce the amount of good (and fresh) Transynd with the replacement of the lost fluid during the filter change.
thanks, and once again welcome.
Ron
Ron,
See my answer above to Wagonmaster2 about filters. This may help. If not, please keep asking and I'll try to deliver !!!
Ron,
Are you running Allison Gold Series filters or the High Capacity filters? Or are you running some "aftermarket" filters?
I'm using the high capacity part number 29545779. I purchased the Transynd and filter kit from a certified Allison dealer in Bakersfield CA.
Ron
Ron
Tom Johnson
Avon, IN 46123
