Leveling issue on 2003 Monaco LaPalma
AlanMaul
I am new to RVing. I purchased a use 2003 Monaco LaPalma.
I'm having an issue leveling the unit. I follow the instructions in the book and the jacks work just fine. When level, I turn the leveling system off and all is fine. The minute I turn the ignition switch off there is about a 1/2 to one second pause and all the jacks retract.
The system is from Power Gear, and I haven't been able to find any user group. There is no mention of a similar problem in the trouble shooting guide. I have checked and the fluid is full, and clean.
Thoughts please
2 REPLIES 2
Executive45
Do you have the Emergency Brake set?...check that first,...below is a link to all their systems. Plug YOUR info in, model number etc. If all else fails, call Lippert. They have a tech support line.....Dennis
Lippert Systems
We can do more than we think we can, but most do less than we think we do
Dennis and Debi Fourteen Years Full Timing
Monaco Executive M-45PBQ Quad Slide
525HP Cummins ISM 6 Spd Allison
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
dougrainer
I have never heard or had this type problem from a Powergear system. For ALL jacks to retract, that means something is activating all the jack solenoids at the same time. 2003 LaPalma--- is this Ford or Workhorse chassis? Doug
