Leveling jacks...
goufgators
When checking the leveling jacks fluid level, should the jacks be in the stored position or down position? I believe I know the answer (stored) but not sure. / Thanks! / Larry
2017 Winnebago Sunstar (gas)
2005 Honda CRV Toad
Invisi-brake
5 REPLIES 5
Blaster_Man
Stored and do not over fill.
2014 American Eagle
goufgators
Thanks for the replys! / Larry
2005 Honda CRV Toad
Invisi-brake
past-MIdirector
Do not over fill or you'll have a little bit of a mess when you retract the jacks the first time. Excess fluid will be vented out.
2-MTnesters
Should be fully retracted (stored position). This way you can see the actual fluid level in the reservoir.
The Webers
Me- Tim
DW- Dea
Pooch- JoJo boxer/lab mix
2010 Keystone Montana 3400RL Hickory Edition "The Taj Mahaul II"
2004.5 GMC Siera 2500HD SLT CC 4x4,6.6 Duramax/Allison, 3:73 gears, Firestone air bags, Reese 16K slider, TFI 45 gal fuel tank, Rhino Liner
dougrainer
Fully retracted position. Doug
