Location of 2006 HR Fresh Water pump?
tstryk
Our water pump in the 2006 HR Scepter is inoperative and I can't find it! We lived in the rig for a couple months during Hurricane Michael, and I noticed it running excessively when we were having to use the water tank. After a few weeks, we got water pressure back, so I could start hooking up to city water and I didn't think about the pump anymore. Now there is NO response, fuse is good, but no reaction from the pump and no light activity when trying to engage it. Any Idea where I can find this illusive creature?
2006 Holiday Rambler Scepter 40PDQ
2014 Ford Fiesta frog
Tucker the schnauzer, Buddy and Cooper the labs
9 REPLIES 9
Executive45
The manabloc is pictured below. Yours should be behind a stainless steel door on the passenger side. Mine is the second compartment ahead of the drive axle. Mine has a push button to open that door. The aquahot is in the same location. Let us know once you've found it.....Dennis
We can do more than we think we can, but most do less than we think we do
Dennis and Debi Fourteen Years Full Timing
Monaco Executive M-45PBQ Quad Slide
525HP Cummins ISM 6 Spd Allison
2014 Chevrolet Equinox LTZ W/ ReadyBrute
CLICK HERE TO VIEW OUR TRAVEL BLOG
10forty2
rgatijnet1 wrote:
Mine was mounted on the back wall of the wet basement compartment.
X2!
1999 Holiday Rambler Endeavor, 36' Gasser
Triton V10, Ford F53 Chassis
ArchHoagland
Maybe somebody stole it and that's why you can't find nor hear it.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
tstryk
Executive wrote:
It should be in the compartment behind the Manabloc.
What is a Manabloc? I didn't look today, but looked everywhere I could think of on Monday. It seems that HR (Monaco) would put the pumps in the same place on every unit - guess that is not the case!
rgatijnet1
Executive45
It should be in the compartment behind the Manabloc. Open that door and it should be in there. There's a filter on it so that may be all that's wrong with it. OTOH if it ran continuously it may be fried. BTW, your filters should be in that same compartment. Might want to check them while you're there....Dennis
Mr_Mark1
Our Dynasty had it in the water bay compartment between the fresh water tank and the water manifolds. In the center bay, you should have some sliding doors so that you can access that area.
It should be near your water tank like said above.
Good luck,
MM.
Mr.Mark
2021.5 Pleasure Way Plateau FL Class-B on the Sprinter Chassis
2018 Mini Cooper Hardtop Coupe, 2 dr., 6-speed manual
(SOLD) 2015 Prevost Liberty Coach, 45 ft, 500 hp Volvo
(SOLD) 2008 Monaco Dynasty, 42 ft, 425 hp Cummins
Ivylog
Both of mine have been in bays without a slideout above.
Upgraded with a 08 HR Navigator 45โ€™...
77rollalong
find your fresh water tank, look for the lowest line on the tank and follow it and see where it goes, should be about 1/2 inch hose, your pump should be on the other end...
