Look, another Allure thread....
rooney77
So I know I need to leave the gap around the immovable objects, like walls and such, but what do I do around the chair mounts and the seatbelt mounts? Both are just bolted straight to the floor, as is the jackknife sofa.
I haven't really found a good write-up with the snap together flooring where they addressed this.
1997 Minnie Winnie DL 29WU
3 REPLIES 3
rooney77
Well the seats are all out. I was just wondering if I needed to do anything special for the install. I guess I'll go with the floor it and bolt it down option.
ronfisherman
Moderator
Moderator
I have done it both ways. Cutout for the pedestal chair. Or remove chair and then bolt back down after flooring is installed. It depends on how hard it would be to remove the item.
2004 Gulf Stream Endura 6340 D/A SOLD
2012 Chevy Captiva Toad SOLD
ksg5000
I removed the seat - installed the Allure - drilled holes and reinstalled the seats. Been a few years and no problems.
Kevin
