me and friend replaced the curb side rear jack on this bounder in about 90mins
and most of the time was because we re-routed the hyd line, away from the leaf springs, had to cut some metal straps without damaging the line
found the jack on ebay
once you loosen and cap the hyd line
its just removing bolts and replacing the jack
then reconnect the hyd line
SAFETY FIRST
the jack must be retracted, before you start
you don't want to drop the RV on your head
I can explain it to you.
1997 F53 Bounder 36s
