low coolant / add water?
Sir_Traveller
My coolant level is about 2 inches lower than the cold level, do I have to buy and add coolant even though I am not driving the RV right now ? ( its hooked up at an RV park ) Can I just add distilled water?
I will eventually add coolant before I drive it in the future of course but my question is regarding the current situation
I appreciate any ideas and suggestions …
34 REPLIES 34
Monaramblee
Get coolant because you may need to top it off more again if you have a leak.
2008 Holiday rambler Vacationer XL
340 HP Cummins
IB853347201
Definitely add coolant. Do not add water.
2010 Suncruiser
ppine
If you are not driving it, hardly matters.
If you are 50/50 water/AF and you don't live in the Yukon you can add some straight water.
Sir_Traveller
this is a 2003 Ford F-53 gas v10...
CC38EL
Gas or diesel? If gasser, I would wait and see how the level looked after it warms up. If low and no coolant to add, I would put in distilled water...but only just enough till I get the right coolant to put in.
If diesel, I would wait till I started it next time and then see what the level does. If still low but visible in the overflow tank, I would wait till I had the correct antifreeze as the engine require special coolant.
Most diesels have over 10 gal of coolant...most gassers, just 6-7 gal and you can get that anywhere.
Jim
2019 Coachmen Mirada Select 37LS
