lugnut torque for Ford F53
btcruzer
Mounting the wheel/tire now after valvestem extender repair. Need quick verification. I'm thinking 150 to 160?
The Good Times are Coming !
10 REPLIES 10
427435
Hikerdogs wrote:
The original spec for lug nut bolt torque on our 2001 F53 chassis was 140 ft. lbs. About a year after we purchased it we got a certified letter from Ford raising the torque to 160 ft. lbs.
The letter also raised the minimum tire pressure from 70 psi to 75 psi. There were 2 stickers enclosed with the letter, one for the bolt torque increase and 1 for the minimum tire pressure increase. They were supposed to be placed near the original tire pressure sticker. In our case it was on the inside of the drivers door.
Correct answer.
Mark
2000 Itasca Suncruiser 35U on a Ford chassis, 80,000 miles
2003 Ford Explorer toad with Ready Brake supplemental brakes,
Ready Brute tow bar, and Demco base plate.
LVJ58
Original lug nut torque specs in my 2000 owners manual was 140 lb ft. However, I later received notification from Ford revising the torque specs from 140 to 150-165 lb ft.
They also recommend when changing out a wheel the torque be re-checked after 500 miles of travel.
Jim & Sherry Seward
Las Vegas, NV
2000 Residency 3790 V-10 w/tags & Banks System
2003 Suzuki XL/7 toad
btcruzer
Hmmmm- I couldn't find the torque in the chassis manual and I haven't any stickers with torque or air pressures. Did find air pressure listed as 80# on a placard on wall below drivers window, guess that is affected by load and all that. This is an '03 F53 chassis with 19.5 wheels. My wrench goes to 150 ft#s so that is what we'll go with. Thanks to all.
RLS7201
If you have an older F53 chassis (88-97) with 16" rims, lug nut torque is 140 lbs.
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
jbrad13
Just checked my 2014 owners manual. 150 for 19.5 " wheels; 450 for 22.5 " wheels.
Hikerdogs
Hikerdogs
2013 Winnebago Adventurer
fischer
The bolls may be stamped , check them
ford 19.5. 150
22.5. 450
2016 Winnebago 35B v10
2006 Jeep Liberty 4x4
Blue ox Tow Bar
zigzagrv
Don't have the book in hand, but I believe the torque is 140 pounds.
Ron
2003 Gulf Stream Ultra Supreme 33'
F53 Class A
2013 Ford Edge toad
cwit
I believe 19.5 rims are 120. I don't know 22.5
2bzy2c
Here you go...
Says 145 Ft Lbs
My advice is worth exactly what you paid for it.
