M1512 Trace Inverter & Charger
charred51
I have a Airstream Diesel Cutter with a M1512 Inverter Charger. Have power to house battery from outside source but can't get the power from the batteries to the inside of coach. AC comes in but DC doesn't. Had plugged in to RV park's 50 amp. No problem until then. Thank you.
3 REPLIES 3
crasster
So what you are saying is your converter is not working? Trying to understand.
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
MrWizard
Moderator
Moderator
1512 inverter charger, if it's working and charging the batteries
And you have no 12v power in the RV , lights , water pump etc
Battery disconnect is off ? Or bad,
Main fuse at dc distribution fuse center is out ?
What do you mean power to batteries from outside source?
I can explain it to you.
1997 F53 Bounder 36s
enblethen
Check to insure you are getting 12 volts to the inverter. You could have a blown fuse.
Has any battery work been done?
Have you checked and reset small circuit breaker on the inverter? What about the inverter breakers?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
