Maiden Voyage
fivejackie
Took our new 2115 Hurricane 27K on a 6 day maiden voyage. We went to KQ Campground in Julian, CA. Weather was good and the food was great. Their Thanksgiving Dinner, they served, had all the trimmings.
The with the 362 HP V10 pulled the hills with ease. It handeld like a sportscar compared to the Class C 305 HP V10 we had. On the freeway at 70 mph, it felt like we were just coasting along. Common sense took over and I slowed down to 65 mph.
The coach does have a few minor problems.
1: The awning rolls out and doesn't stop. And sometimes I have to roll it in with the out switch, to keep it from rolling the white bottom on the outside.
2. The screen door is about a 1/2 inche short in width, it won't lock.
3. Windshield has a loud whistle of air on the top left side.
4. We have a hole in a pantry door. Door is on order.
5. Kitchen window has a air gap. It doesn't seal.
6. Awning LED lights not working.
7. Outside rear latter has 2 bottom braces cracked.
Don and Jackie
2115 Hurricane 27K
2113 Redhawk
1992 Pace Arrow
10 REPLIES 10
Effy
hanko wrote:
I see in a 100 years Thor still hasnt got their act together
Talk about a wet blanket post. Because no other brands ever experience a punch out list or problems, right?
2013 ACE 29.2
hanko
2014 Tiffin Open Road 36LA,Banks Power pack,sumo springs, 5 star tune, magnum invertor
2013 Ford Focus Toad
Haigh Superstar
J-Rooster
Don, not a bad first time fix list. Probably be one more fix list and you will have all the bugs out. Have fun in your new coach.
prstlk
Back to dealer with a list. Not telling you how to live your life but my response to the dealer would be "here's the list..fix it! Have some patenice but not much. You can also check and remind the dealer of lemon laws for your state. If they get pissy you can remind them of the power of social meadia to burn their butt cheeks. The more we post and disscuss the dealer problems, the faster the sleazos will be gone.
Just say in
2007 Keystone Challenger 5th wheel, Ford F350 Super Duty 6.7L Diesel, Short Bed, 2 dogs and the cat and rolling down the road full time since May 2014
fivejackie
Thanks for the your reply. My other RV's had an awning automatic stop. The screen door hinges looked ok, will check again. I will check the weep holes on the drivers side,hope that is the problem. Its will be raining today and tomorrow, this should be a good test for any leaks.
Don and Jackie
2115 Hurricane 27K
2113 Redhawk
1992 Pace Arrow
Effy
The awning does not have an auto stop when it's deployed so that's not broken. It will stop however when rolled back in. The whistle could be your weep holes. If it's not leaking then I would suggest getting weep hole covers. This is a common noise. Screen door is short? That could be a bent hinge on the door itself, replace to fix. hopefully it's not an indication of a bigger problem where the hole for the door is cut too big, although I imagine you'd have problems with the main door if that were the case. The air gap in the kitchen window could or has caused a leak. make sure you check walls and cabinets below this to ensure there is no water damage. Hopefully replacing the window will fix it.
2013 ACE 29.2
janstey58
Is this 2115 unit equipped with Hovercraft functionality? 🙂
Jeff and Kim
2015 Fleetwood Discovery 40E
Freightliner Chassis 380HP DP
2012 Ford Escape Limited Toad
msmith1199
The whistle in the windshield and the air gap in the kitchen window could be major problems. Make sure those get fixed correctly and not just filled with calking. Where air can get it water can get in and water messes stuff up.
2021 Nexus Viper 27V. Class B+
2019 Ford Ranger 4x4
Steeljag
Future RVs are still having too many problems!
2018 Forester 3011DS
2010 Flagstaff 26RLS (Sold)
2012 Ford F-150 Screw Ecoboost H/D 3.73
1930 CCC
Going where the weather suits my clothes !
wildtoad
So you're driving an RV 100 years before it's due to be built. (2115 ?) No wonder it drives like a dream. Glad you had a good time and hope the dealer can fix the deficiencies.
Tom Wilds
Blythewood, SC
2016 Newmar Baystar Sport 3004
2015 Jeep Wrangler 2dr HT
