Jul-27-2018 04:10 AM
Oct-05-2018 12:04 PM
mamaw56 wrote:
We have till December of 2019 when we move into our apartment. At that time we hope to sell it and get a small used class C or class B so we can continue to part time travel.
Oct-05-2018 10:31 AM
Oct-05-2018 10:24 AM
mamaw56 wrote:
...These past two years it’s been rockin’ the checkbook. Not much else can happen except the fridge is still kicking. Fingers crossed...
Oct-05-2018 08:29 AM
mamaw56 wrote:I'm confused, why would the RV repairman not be able to replace the starter? Its not like the starter is hard to access. Was the burnt wire repaired or replaced? When I hear thinks like this, it makes me ashamed to have been a mechanic and have run a shop. Do people not have a conscious anymore? Sure, people need to make a living, but come on. Sorry for your problems, I guess I'm just venting.
We’re fulltime, longest we sit is 3 weeks never near salt water. Mechanic looked at it and found a burned wire at one of the connections. He is calling in another mechanic who works on chassis and said theyd replace the starter. My husband has vertigo and the house spins when he looks up so he hasn’t been able to even look at it himself but all the suggestions here sound viable. We’re going to suggest this to the mechanic. After 20 years things start to happen. These past two years it’s been rockin’ the checkbook. Not much else can happen except the fridge is still kicking. Fingers crossed...
Oct-05-2018 06:36 AM
Oct-05-2018 05:02 AM
Oct-05-2018 04:30 AM
Oct-04-2018 04:14 PM
Oct-04-2018 11:24 AM
Oct-04-2018 08:44 AM
Oct-03-2018 08:59 AM
mamaw56 wrote:
So we had the mass air flow sensor replaced again with an after market one as ford doesn’t make the part anymore. The computer was replaced, we also replaced the batteries. Now it won’t start. Got it started after it wouldn’t turn over it just clicked. Finally started and it made a loud gear grinding sound, kind of like when you turn your key on but the car is already running? When the noise stopped the engine ran quiet. Turned it off but now it won’t start. It doesn’t even click. What could it be, were thinking the starter. Is that a reasonable conclusion?
Oct-03-2018 06:54 AM
Oct-02-2018 10:44 PM
Jul-28-2018 02:35 PM
amxpress wrote:
If there was an open or short in the MAF circuit, your “Check Engine Light”would come on and a code would be set. If the engine was running well to begin with and you disconnect the MAF sensor, not only will a code be set but the engine will go into a Failsafe mode and will run like ****.
Is the check engine light on? If so, what is the DTC?(Trouble code)
