MH listing to one side
RoadWarriors2
Whether levels are down or MH is moving, it's lower about 2 inches on the right side. Weight is not an issue. Any ideas on the cause? An appointment with Freightliner may be next....
Tony & Maria :B
2007 Tiffin Phaeton 40 QSH
Cat C7
Freightliner
Allison 3000
Jeep Liberty
Viet Nam Vet 66-67, 173rd Assault Helicopter Crew Chief - "Robin Hoods"
Travel Blog: www.roadwarriors2.blogspot.com
Another day, another 100,000 brain cells gone........
8 REPLIES 8
SoCalDesertRid1
It may be taking on water which is caught in the bilge on that side.
Oh, sorry, that was boats.
01 International 4800 4x4 CrewCab DT466E Allison MD3060
69Bronco 86Samurai 85ATC250R 89CR500
98Ranger 96Tacoma
20' BigTex flatbed
8' truck camper, 14' Aristocrat TT
73 Kona 17' ski boat & Mercury 1150TB
92F350 CrewCab 4x4 351/C6 285 BFG AT 4.56 & LockRite rear
RoadWarriors2
Doug,
I'm getting a message: "Page cannot be found". I'll try direct to askattwood.com
Thanks.
Update -
OK thanks.
Tony & Maria :B
Cat C7
Freightliner
Allison 3000
Jeep Liberty
dougrainer
I cannot get the Atwood link to work. BUT, if you have the Atwood manual that comes with the jacks. The Terminal P wire is the place to connect 12 volt positive to. That will engage the air valve solenoids to CLOSE and allow the Chassis air bags to inflate. Doug
Bill_Satellite
If you cannot get under your coach without the jacks extended please do not extend them and use them only to get under the coach. You could raise the coach and install some proper jack stands but many RVers have been injured or killed when the jacks failed or unexpectedly retracted.
Can't we all just get along?
dougrainer
Leveling jacks extended are not required to repair the chassis Air leveling system. Leveling jacks are an ADD ON option. Now, if you are talking about CLOSING the Air dump solenoid valves(Atwood control box does interface with the Chassis air solenoids), you can jump the air valve wire at the Atwood control box (not the dash touch pad) to close the air valve solenoids. The procedure is outlined in the Atwood operators manual. Doug
RoadWarriors2
UPDATE:
Now having a problem with Attwood Jacks ( yes, it's our turn :R ), and can't get the Height Control gizmo fixed until the coach can be raised.
Question: Can a problem occur if the coach lists 2 inches to one side?
ie: does this listing issue have to be resolved?
Thanks in advance.
Tony & Maria :B
Cat C7
Freightliner
Allison 3000
Jeep Liberty
RoadWarriors2
Ivylog - thanks - that's a big help.
Tony & Maria :B
Cat C7
Freightliner
Allison 3000
Jeep Liberty
Ivylog
Ride height valve/rod needs adjusting or is broken. The rod has a rubber end that often ages and breaks... easy fix.
Upgraded with a 08 HR Navigator 45โ€™...
