First of all, congrats on your new coach.....only safe and happy travels........
Most likely you have a power management system....yes, if you want to use everything like 2 ac's and electrical appliances..you should have a fifty amp hook up....but if hook to less than that say 30 amp, your EMS will cut out in order items to keep you from going over..such as one ac at a time etc..15 amps will keep your charger going and let you run the fridge on electric and use electrical appliances..probably won't run an AC but will keep you going..just make sure you hook up to a good electrical connection with no open ground or open neutral or miswired post...invest in a surge protector from progressive, the electrical system you save will be your coach..recently I had a bad post and had to live on 30 amps for two days..putting fridge on gas and water on gas...once charger charged the batteries...the EMS managed the AC's nicely and I was able to run the washer as well.
Stuart and Stella Denning
2016 Entegra Aspire 42RBQ
The 3 Bulldogs (Daisy, Sylvie and Stashie)
2018 Equinox Diesel (TOAD)
