No 110 power inside (Solved, Thanks)
howdy35
I have a 1999 National Tradewinds with no 110 power in the bathroom and up front to the tv. I have tested the breakers in the bedroom and all the breakers are working ok. I pulled the outlet in the bathroom and have no power to it. The gfci breaker on that outlet is okay but I have no power to the outlet.
I'm not sure where to took next. Any ideas?
(Solved) It was one of the breakers on the inverter. Thanks for your help. I just got another opportunity to learn more about my coach.
1999 National Tradewinds 7370
2014 Honda CR-V--Toad
Fulltime
10 REPLIES 10
2bzy2c
Thank you for updating. So many leave us hanging.
My advice is worth exactly what you paid for it.
howdy35
I do have power in the bedroom and at the sink but I will check the inverter in the morning. Thanks
Fulltime
I_rv
i have 2001 tradewinds probably one of the two breakers on the inverter
wallynm
I would check the 110 side of the ATS.
Have a Diesel Engine Diesel RV Club
Have a Freightliner FCOC Web Page
Living on the memories now
EX 02 DSDP 3567
EX 99 Coachmen
EX 86 Georgie Boy
EX 75 Winnie
EX 72 Sightseer
EX 68 Brave
THOSE THAT DO NOT KNOW HISTORY ARE DOOMED TO REPEAT IT
Effy
You at a CG? Is there power at the post? WHat happens if you run the gen? You get power then? It happens to me when I am on 20a at home if I trip the house breaker.
2013 ACE 29.2
enblethen
Continuity on both sides? What about incoming power to the GFCI receptacle?
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
howdy35
I went to the main breaker box in the bedroom and tested each breaker both on and off to see if I was getting 110 out of the breaker. Each one worked okay. The gfc "recepticle" in the bathroom has continuity to both sides. I have not checked the inverter. I did not think of that. Thanks for your help.
Okay, I checked the inverter and one of the buttons on the outside, which I assume are (trip breakers) was out. I reset it and "volla" I now have power. Thanks to all for your help. Another learning lesson for me.
Fulltime
enblethen
Do you really have a GFC breaker? Most rigs have GFCI receptacles.
Have you checked the GFCI receptacles?
You say the breakers are working, did you check for actual 120 volts leaving the breakers? Did you try to reset the circuit breakers? Turn all breakers off, applying light pressure toward off, turn on main breaker, then turn on branch breakers one at a time.
Bud
USAF Retired
Pace Arrow
Mandalay_Parr
Maybe your inverter has a breaker right on it?
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
downtheroad
Sure sounds like a GFI to me. Are you sure that there isn't another one somewhere....I have 3 scattered about.
"If we couldn't laugh we would all go insane."
Arctic Fox 25Y
GMC Duramax
Blue Ox SwayPro
