Nov-06-2020 11:24 AM
Nov-07-2020 12:41 PM
enblethen wrote:
Sure sounds like it is the multi-function switch in the steering column or the wiring between it and the relay.
Is your relay and wiring in the compartment on outside below the driver?
Nov-07-2020 11:45 AM
Bud
USAF Retired
Pace Arrow
Nov-07-2020 11:06 AM
enblethen wrote:
First click should be parking lights, second should be headlights.
Post relay and headlight part numbers.
Nov-06-2020 08:56 PM
Nov-06-2020 06:15 PM
Bud
USAF Retired
Pace Arrow
Nov-06-2020 05:44 PM
enblethen wrote:
In theory the low beam relay would be energized by the ignition switch. Low beams would go out when high beams come on.
A set of contacts in the low beam relay could be bad if my theory of operation is correct.
If low beam relay is the same as high beam or if you have old relay, change out low beam relay.
Nov-06-2020 05:41 PM
Nov-06-2020 05:22 PM
Bud
USAF Retired
Pace Arrow
Nov-06-2020 05:11 PM
Bud
USAF Retired
Pace Arrow
Nov-06-2020 05:02 PM
enblethen wrote:
Did you check for control power at the relay coil? Other side of coil should be ground.
Jumper the contact point in the relay socket to see if high beams come on.
Nov-06-2020 04:33 PM
Bud
USAF Retired
Pace Arrow
Nov-06-2020 03:24 PM
Charley67 wrote:
I just resolved a problem with no low beams. I was about to go into the steering column and look at my multifunctional switch, but I saw that my headlights relay was the same as one right beside it, so I switched them and bingo, lights working bright and dim. $21 at parts store and all is well. Good luck.
Nov-06-2020 03:19 PM
enblethen wrote:
Am guessing you have a multi-function turn signal switch assembly. Have you checked for control voltage to the high beam relay? Does your turn signal lever allow for pulling up for energizing the high beams and down to lock in high beams?
Nov-06-2020 03:00 PM
Ivylog wrote:
Do you have a smart steering wheel?
Nov-06-2020 02:58 PM
