No power to thermostat
Blackdiamond
Thermostat seemingly has no power. Nothing is on the display, I have checked the fuse and it was fine, replaced it anyway. What else should I look at? It worked fine 2 weeks ago.
03' Fleetwood Southwind 32VS
Enclosed Trailer hauling the toys
05 525 EXC KTM
15' FE350s Husqvarna/KTM
07 Rhino, long travel, 4 seater
9 REPLIES 9
enblethen
Did you check for fuses in the panel adjacent to the AC breakers/
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
tahiti16
When I had that issue it was the fuse/service switch inside the outside access door. Finally found a new one and it trips to so just jumped it out, my board has a fuse to protect everything so this is redundant.
Ray, Cheryl & of course Miss Molly the four-legged child
2006 Dolphin 36' F53 V10 5 speed auto 2 slides 7.5 KW genset
enblethen
Pull the fuse where you are reading the 7 volts and see if it goes up.
If it doesn't you need to follow the circuit back to where it drops.
Bud
USAF Retired
Pace Arrow
Blackdiamond
Yes connected to 15amp shore power, batteries are good reading about 12.7 before I plugged in.
05 525 EXC KTM
enblethen
7 volts? you have a 12 volt issue in your rig. Are you connected to shore power? What is your battery condition?
Have you checked main fuse if equipped in 12 volt distribution panel
Bud
USAF Retired
Pace Arrow
Blackdiamond
enblethen wrote:
Which fuse did you check? One in thermostat or one in 12 volt DC power distribution panel?
Did you check for power at the fuse contacts?
What is make and model of thermostat?
Rv Products, RVComfort.zc is the make and model, I checked both fuses, they are good, and have about 7 volts at the power distribution panel fuse.
05 525 EXC KTM
Jagtech
Replace the internal battery?
1998 Triple E F53
1995 Jeep Wrangler toad
John_Wayne
are you sure it doesn't have a batt. and if not what is the house batt. reading.
John & Carol Life members
01 31'Sea View single slide, F53 V-10 with 134,000 miles and counting.
2012 Jeep Liberty Smi brake system
Security by Bentley
God Bless
KF6HCH
enblethen
Bud
USAF Retired
Pace Arrow
