Norcol refigerator problem
Obatanga
Hi folks. Finally getting the Minnie Winnie out of storage for a trip. This time, the Norcold refrig burner won't fire. What usually causes this? Propane is flowing, but no refrig fire. Don't want to push it so as not to blow the circuit board. Thanks for your help!
David & Julie & the dogs who don't listen
7 REPLIES 7
jamesa403
I have had the same problem from spider's in the flue. Blow it out with a compressor and try again.
TyroneandGladys
Mine would not lite took some compressed air and blew the burner area out fired right up
Tyrone & Gladys
27' 1986 Coachmen
mockturtle
SCVJeff wrote:
Have you purged the line? Turn on the stove and keep sparking, or just hole a butane lighter next to it till you get flame and try the fridge again. This is a common and normal problem when coming out of storage and trying to light things.
X2
2015 Tiger Bengal TX 4X4
Chevy 3500HD, 6L V8
SCVJeff
Jeff - WA6EQU
'06 Itasca Meridian 34H, CAT C7/350
GrumpyandGrandm
Or you could have a spider web in the burner tube.
Grandma in front of her retirement home..
She lets Grumpy drive!!
Obatanga
Thanks, btd. I am hearing the snap, then nothing. Probably needs cleaned out then.
btd35
Do you hear the spark snapping for ignition? If you don't, then it's most likely the spark module and or ignitor. If you do, then it may be that rust and corrosion is deflecting the gas flow around the gas orifice, and it needs to be cleaned.
Tom & Beth
05,Grand Junction 35TMS
99, Dodge 3500 Dually.
