Onan microlite 4000
myface
I have Onan Microlite 4000 4KY FA261100J. Does any one have wiring diagram for that genset. I have 3 different but none shows wiring for mine. What is most confusing, all shows 15 pin connector and mine have way more pins going to computer. I am having problem with fuel shut off solenoid - not getting voltage. Previous owner replaced carburetor and mess up the wiring going to fuel shut off solenoid. I am trying to locate the pin so I can bypass the wire and run new one. The gen will run if I jump 12v to that solenoid.
30 REPLIES 30
myface
At the end of my model# there is J, but the manual said is H. More confusion. All of them shows 15 pins, I count 17 in mine.
enblethen
You are somewhat correct, the spec H has both. Spec J does not have a solenoid. Look at pages 18-21.
Parts Breakdown
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
enblethen
That is the fuel pump!
Bud
USAF Retired
Pace Arrow
myface
enblethen wrote:
Is your genset LP or gasoline?
I wish of LP, but is gas. The shut off solenoid is at the bottom of carburetor.
enblethen
Bud
USAF Retired
Pace Arrow
myface
I did jump the solenoid and gen works, but to shut down, I had to remove the jump (12V to solenoid).
enblethen
The connector should be marked for pin one and the last pin, normally in opposite corners. Then use meter to test for continuity.
Are you sure it is a solenoid and not a pump? Gas engines are fuel pumps. LP engines are solenoids.
Have you tried applying 12 volts DC to input to see if it works?
Bud
USAF Retired
Pace Arrow
myface
The pics are in http://jestarkel.com/pics/1.jpg and http://jestarkel.com/pics/2.jpg
myface
I do apologize for not responding. My internet is buggy. Is there any way to insert image to post?. My computer have 23 pins, but the connector use only 18 pins. This is where my confusion begins. The only way for me to trace the wire would be to take the carburetor and manifold off. I will try to upload to one of my website and post a link.
enblethen
Let me try it again!
Diagram 12-21 is for 60 Hz. Others were for 50 HZ. Pin numer stays the same.
Bud
USAF Retired
Pace Arrow
enblethen
Pin J1-3 goes to fuel shut off
Bud
USAF Retired
Pace Arrow
enblethen
I am guessing you have Spec J.The circuit board is updated to a 327-1413RV
Electrical drawing in manual appears to be 12-16.
How many wires come off your circuit board?
Edit It is diagram 12-17
Bud
USAF Retired
Pace Arrow
enblethen
What is the Spec letter of your genset?
Bud
USAF Retired
Pace Arrow
myface
I got the maintenance manual, but all of them shows only 15 pins. The computer is 300-5046. I can not locate wiring or pins for that computer.
MountainAir05
https://www.bing.com/images/search?q=onan+microlite+4000+4ky+fa26100j+wiring+diagram&id=4263C7210ABA220D6B187BE7BC2B37CA22E92750&FORM=IQFRBA
http://rvwithtito.com/download/Onan4000MaintenanceManual.pdf
