Oct-22-2013 12:13 PM
Oct-28-2013 01:05 PM
Oct-28-2013 12:22 PM
Berner2 wrote:Excellent point. All the following is in layman terms, so please bare with me. Many of the older generators were set up to run off the liquid side of the tank, and had a vaporizer regulator at the generator. The newer ones are set up to run on vapor. ASME tanks found mounted in motorhomes have a liquid discharge valve and a vapor discharge valve. LP-gas inside a container is in two states of matter, liquid and vapor. The liquid portion of a container is in the bottom area and the vapor is in the upper area above the liquid. Contaminants in the propane will settle to the bottom liquid portion of the tank. If the generator is drawing off the bottom liquid side of the tank, the contaminates can enter into the line feeding the generator and gunk up in the generators LP regulator/vaporizor, requiring it to be re-built or replaced. Much less likely when running off the vapor side of the tank.
When I got it back I swapped it from the liquid side of the tank to the vapor port. Works like a champ now. Hopefully you don't have this same problem.
The liquid to vapor swap is supposed to eliminate the gumming up. Just a thought.
Oct-28-2013 08:22 AM
Oct-22-2013 01:45 PM
Oct-22-2013 01:31 PM
Oct-22-2013 12:21 PM
