Polish types
anon125
when we bought our MH in 2006 we were persuade to get a coating that protects against oxidisation.
even after expensive reapplications it does not work.
so apparantly we can have the oxidization removed and repolished.
is carnuba?? wax just as good?
how long does it last?
and the brown decals look very dull.
thanks all
12 REPLIES 12
anon125
thanks Mike
REWahoo
anon125 wrote:
enuf of europe already
Isn't it terrible when you lose control of the conversation? 🙂
2011 Silverado 2500HD LTZ Duramax 4x4
2007 Jayco Eagle 291RLTS (trade in)
2017 Jayco Eagle HT 27.5RLTS
Mike_M2
No to Polish!
After spending money on every type of wax you could think of, i found the best solution for the least amount of work(and my old 1999 Four Winds never had a lick of wax on it). Start with a coat of 3M Restorer and wax, apply and do not let dry, remove immediately. This will remove any oxidation and start the wax process. Next use Meguires Marine wax, applying the same way, no dry time. Other waxes on top of the 3M would seem blotchy. Do both in small sections. You won't beleive the shine.
Mike M2
Thor Infinity 33SL
anon125
JR45
This is what I used on my Alpenlite the best that I have ever used to remove oxidation on gelcoat plus the Porter Cable 7424XP and Foam Pads. The best way to clean pads and rags is with this product, they turn out like new.
http://www.autogeek.net/dp730.html
http://www.autogeek.net/3m-marine-restorer-wax.html
JR
2006 Country Coach Inspire 360 40ft Genoa Designer Series Cat C9 Samsung 197 RR
Aluminum Radiator was recently replaced with a STEEL & COPPER Bolt Together Radiator w/ updated rubber mountings
SilverLeaf VMS 330
Toad--2011 Ford Edge Sport, Air Force One
:C
wny_pat1
joeprinter wrote:
REWahoo wrote:
Polish types? There's an entire European continent with all sorts of choices, but I don't advise using Greece for your Finnish. Czech the thread later to see if anyone recommends going Dutch. 🙂
Haha first thing I thought of too, well was wondering if the OP wanted to know about different "Polish Hot Dogs" hahaha:)
Ever ask a Polish person in Poland where to get Kielbasa. I once did and got a question back - what kind of Kielbasa. Kielbasa in Poland is like sausage here - hot dogs of different types, and many varities of sausage - and not one specific type of sausage. Kielbasa, kolbasa, kolbasa, kobasa, kolbasi, kovbasa, kobasi, and kubasa are common North American anglicizations for a type of Eastern European sausage. Synonyms include Polish sausage, Ukrainian sausage, etc. In English, these words refer to a particular genre of sausage, common to all Eastern European countries but with substantial regional variations
“All journeys have secret destinations of which the traveler is unaware.”
anon125
thanks all
joeprinter
"2012 Forest River 360 DS"
"Ford V-10"
"2013 Toyota Corolla on Tow Dolly"
rgatijnet1
Get a marine polish made for fiberglass. You can go with the floor coating, as many have, but you will also find that many have had it peel off. Do a search of the various posts about using floor coating on your RV and read about the problems. Any exterior boat polish/coating will probably contain some UV protection which may help prolong the decals and help prevent oxidation of your gelcoat. The floor coating does not contain any UV protection and it may peel from dark surfaces.
wny_pat1
In the case of your specific coach, a marine wax specifically designed for gelcoat fiberglass. It will probably provide the longest lasting protection short of clearcoat paint. Many use a floor polish called Zep Wet Look (aka Red Max Pro) which has a big following around here and on other RV sites. It is basically similiar to a thin plastic clear coating which can be long lasting, and can out last wax. You can find similiar plastic coating in the marine/RV markets that are long lasting, but more expensive because they serve the marine and RV markets.
REWahoo
frankdamp
I use a cleaner/polish that is made specifically for fiberglass (originally for boats). It's a house brand from West Marine. It works very well on the white fiberglass, but doesn't protect the vinyl decals very well. They were pretty ratty when we bought the rig and I didn't expect the polish to be much help for them.
Frank Damp, DW - Eileen, pet - female Labrador (10 yrs old), location Anacortes, WA, retired RVers (since Dec 2014)
