Power converter fridg and microwave
iamalienru
I got a power surge to my coach which is a 1998 American eagle now my refrigerator microwave and power converter are not working air conditioning is working fine off of 50 amp fridge works on gas microwave has power to the plug but the on and off switch will not give it power beakers all seem to be switching on power converter says no Ac power generator will not give Ac power either where to start is the question thanks
Tom
9 REPLIES 9
wa8yxm
Assuming you got a true surge.. Every device that you say is not working has electronics.. Now a surge (Sustained increase in voltage) can often fry some of the components.
With luck, a fuse (There are several in a fridge, Dometic has a circuit board on the bottom of the outside compartment with fuses, and a box (Black) on the left side with more fuses. Norcold I do not have so can not comment.
Converters are electronic devices, may have fried, may have just popped a fuse.
(Same with Microwave)
Recommendation, install a Progressive Industries HW-50 as part of your repair so that the next surge,, will be stopped.
dougrainer
Your 120 fuse on the Refer is blown. Possibly the 120 element also
Your Microwave is FRIED ---replace it not worth repairing
Your Converter is fried. replace it.
CALL your insurance company. Doug
dougrainer
Sam Spade wrote:
Old-Biscuit wrote:
There is no 220.......
There are TWO 120V on RV 50A
How about giving it a rest, OK.
The so called 50 amp service for an RV consists of two hot feeds of 110/120 volts 180 degrees out of phase and a common neutral.
The 220/240 is there if one chooses to use it that way.
I agree about the error of what you posted. When you post what you posted, people that don't understand will think they have REAL 220 to their RV. While you are technically correct, it just confuses people. I NEVER state this when explaining or troubleshooting Shore power problems to customers. Doug
Old-Biscuit
But it is NOT used that way.
It is TWO 120V AC hot legs----50A each leg
One hot feeding 1/2 of AC Panel and the other hot feeding the other 1/2
Calling it 220 just confuses those that don't understand it is split.
Sam_Spade
'07 Damon Outlaw 3611
CanAm Spyder in the "trunk"
Old-Biscuit
Sam Spade wrote:
I would say that one side of your 220 is dead.......but your tests seem to rule that out.
So there is only one logical conclusion left, I think:
Those items that are not working are damaged internally; IE they are fried.
Microwave has 120V AC at outlet but no ON/OFF..........internal ceramic fuse blown
Fridge woks on gas but not on AC....check outlet fridge is plugged into for 120V AC. If outlet has power then 5A (possible 8A ---varies with models) glass fuse on fridge control module is blown or electric element is bad
If fridge outlet does not have AC power check for a GFI outlet that is tripped
Converter.....if it is plugged into an 120V AC outlet.....is outlet hot.
IF no--check for tripped GFI outlet
If yes..converter blown
If converter is wired to a 120V AC circuit breaker..then CB tripped
push CB handle to OFF then back on
If CB good....then converter blown
Remember.........120V AC circuit breaker does not always 'look' like it tripped. Turn them OFF then back on to reset.
And test fuses vs look at them
Meter is your friend.....
Mandalay_Parr
Start by getting an electrical person to help you and a meter. Just take one item at a time.
Converter-no ac power. Start checking input and output with a meter.
Check power output from generator with a meter.
I do think you need someone to help you.
We can help over the phone too.
Jerry Parr
Full-time
2005 Mandalay 40B
Cat C7 350, 4 Slides
Blue Ox, Brake Buddy
2004 CR-V Toad
jrparr@att.net
602-321-8141
K7OU - Amateur Radio
Kenwood Radios
ARRL, W5YI, & LARC VE
SKYWARN Weather Spotter
Sam_Spade
2oldman
OP copied and punctuated for clarity:
I got a power surge to my coach which is a 1998 American eagle.
Now my refrigerator, microwave, and power converter are not working. Air conditioning is working fine off of 50 amp, fridge works on gas, microwave has power to the plug but the on and off switch will not give it power. Breakers all seem to be switching on power. Converter says no Ac power, generator will not give Ac power either.
Where to start is the question. Thanks
