Power gear electric levelers
captpar
Drivers side rear jack won't go down,changed brake and motor still no go,will go up and down on 12 volt battery hookup. 2008 fleetwood discovery . At wits end . This is the 3rd time with this jack,both other times it took a new brake and sealant to fix. Any advice would be greatly appreciated. No help from power jack.
6 REPLIES 6
daytripper63
When you unplug all the connections put some dielectric grease in all the plug connections as well
2008 FLEETWOOD PROVIDENCE 40X
tinkerer
The instructions from power gear will inform you how to recalibrate the jack. If it works with 12 volts I am guessing they are need to be calibrated. These levelers are problamatic and most of the problem comes from the internal brake that get corroded. I know because I have the same jacks on my 2007 Discovery. The seal kit is available on Fleetwoods web site.
dtgunner7
What Southwind said run ALL Jacks down by control panel or 12v supply and reset control panel. If you don't you may shear pins in unit...
Southwind98
Couple of things to check, which you may already have done. Find your control box , mine was by entry door behind the slide, check all connection. Actually pull them out, I had a loose connection and it cause the jack to become nonoperational. Second if haven't already done so, run all the jacks down including the one not working, to where the magnets clear and reset the control panel. Good luck.
Will & Michelle
2008 Fleetwood Bounder 38P
2005 Jeep Wrangler Unlimited
1990 Jeep Wrangler
Blaster_Man
Crazy Ray wrote:
Call Fleetwood 1-800-322-8216 ask for Tech support.
When I called with a similar problem, FW said to call Power Gear.
2014 American Eagle
Crazy_Ray
RET ARMY 1980,"Tiny" furkid, Class A, 2007 Bounder 35E, Ford V10 w/Steer Safe, 4 6V CROWN,GC235,525W Solar Kyocera, TriStar 45 Controller,Tri-Metric 2020,Yamaha 2400, TOW CRV. Ready Brake. "Living Our Dream" NASCAR #11-18-19-20- LOVE CO,NM,AZ
